minimum.exe showing as failure in some test reports
Wed Jan 25 15:41:35 UTC 2023
Hi
I see minimum showing up in some test reports on build@ as a failure. This
is one example:
https://lists.rtems.org/pipermail/build/2023-January/039635.html
What do we need to do to handle this without duplicating a lot?
Thanks.
--joel
URL: <http://lists.rtems.org/pipermail/devel/attachments/20230125/08128c37/attachment.htm>
