minimum.exe showing as failure in some test reports
Sebastian Huber
Wed Jan 25 15:47:37 UTC 2023
On 25.01.23 16:41, Joel Sherrill wrote:
> I see minimum showing up in some test reports on build@ as a failure.
> This is one example:
> https://lists.rtems.org/pipermail/build/2023-January/039635.html
> <https://lists.rtems.org/pipermail/build/2023-January/039635.html>
> What do we need to do to handle this without duplicating a lot?
The basic problem is that the RTEMS Tester learns the expected test
state from the test output. When there is no output, the tester doesn't
know the test state.
One option is to add the test state to the ELF file through a note (ELF
annotation).
embedded brains GmbH
Herr Sebastian HUBER
Dornierstr. 4
82178 Puchheim
Germany
phone: +49-89-18 94 741 - 16
fax: +49-89-18 94 741 - 08
Registernummer: HRB 157899
