[RSB 5] Remove aarch64 and microblaze from RSB on 5 branch
Mon Jan 30 14:44:11 UTC 2023
Closes #4555.
 rtems/config/5/rtems-aarch64.bset    | 4 ----
 rtems/config/5/rtems-all.bset        | 2 --
 rtems/config/5/rtems-microblaze.bset | 3 ---
 rtems/config/5/rtems-tier-4.bset     | 1 -
 4 files changed, 10 deletions(-)
 delete mode 100644 rtems/config/5/rtems-aarch64.bset
 delete mode 100644 rtems/config/5/rtems-microblaze.bset
diff --git a/rtems/config/5/rtems-aarch64.bset b/rtems/config/5/rtems-aarch64.bset
deleted file mode 100644
index f38aff3..0000000
--- a/rtems/config/5/rtems-aarch64.bset
+++ /dev/null
@@ -1,4 +0,0 @@
-%define release 1
-%define rtems_arch aarch64
-%define with_libgomp
-%include 5/rtems-default.bset
diff --git a/rtems/config/5/rtems-all.bset b/rtems/config/5/rtems-all.bset
index 00ccfae..81076e4 100644
--- a/rtems/config/5/rtems-all.bset
+++ b/rtems/config/5/rtems-all.bset
@@ -1,11 +1,9 @@
-5/rtems-aarch64
 5/rtems-arm
 5/rtems-bfin
 5/rtems-epiphany
 5/rtems-i386
 5/rtems-lm32
 5/rtems-m68k
-5/rtems-microblaze
 5/rtems-mips
 5/rtems-moxie
 5/rtems-nios2
diff --git a/rtems/config/5/rtems-microblaze.bset b/rtems/config/5/rtems-microblaze.bset
index e5c23af..0000000
--- a/rtems/config/5/rtems-microblaze.bset
+++ /dev/null
@@ -1,3 +0,0 @@
-%define release 1
-%define rtems_arch microblaze
diff --git a/rtems/config/5/rtems-tier-4.bset b/rtems/config/5/rtems-tier-4.bset
index 24d392d..042f2a0 100644
--- a/rtems/config/5/rtems-tier-4.bset
+++ b/rtems/config/5/rtems-tier-4.bset
@@ -5,6 +5,5 @@
 # anyone working on adding a BSP.
 5/rtems-epiphany
-5/rtems-microblaze
 5/rtems-riscv
 5/rtems-x86_64
1.8.3.1
