[rtems commit] xilinx-zynqmp: Include <rtems/libio.h> for rtems_termios_initialize()
Wed Jun 7 15:57:57 UTC 2023
I grep'ed for calls to rtems_termios_initialize and found a lot of calls to
remove. I got it building again. If someone wants to sweep those calls out,
go for it.
The bigger alternative seemed like work being pushed on the community to
keep the tree building and finish a job. I don't have time to do someone
else's clean up
--joel
On Wed, Jun 7, 2023, 10:15 AM Gedare Bloom <gedare at rtems.org> wrote:
> This is a reasonable workaround for now, but it seems to be overkill
> and counter to the point of refactoring the termiostypes.h.
> Would a better solution be
> #define rtems_termios_initialize() (void)
> On Tue, Jun 6, 2023 at 4:34 PM Joel Sherrill <joel at rtems.org> wrote:
> > Module:    rtems
> > Branch:    master
> > Commit:    b2967081e5daa673141d714a2e53280898dce566
> > Changeset:
> http://git.rtems.org/rtems/commit/?id=b2967081e5daa673141d714a2e53280898dce566
> > Author:    Joel Sherrill <joel at rtems.org>
> > Date:      Tue Jun  6 17:33:08 2023 -0500
> >  bsps/aarch64/xilinx-zynqmp/console/console.c    | 1 +
> >  bsps/arm/xilinx-zynqmp/console/console-config.c | 1 +
> >  2 files changed, 2 insertions(+)
> > diff --git a/bsps/aarch64/xilinx-zynqmp/console/console.c
> b/bsps/aarch64/xilinx-zynqmp/console/console.c
> > index 992b8a62da..e0ca14069c 100644
> > --- a/bsps/aarch64/xilinx-zynqmp/console/console.c
> > +++ b/bsps/aarch64/xilinx-zynqmp/console/console.c
> > @@ -38,6 +38,7 @@
> >  #include <rtems/bspIo.h>
> >  #include <rtems/endian.h>
> >  #include <rtems/sysinit.h>
> > +#include <rtems/libio.h>   /* for rtems_termios_initialize */
> >  #include <bsp/aarch64-mmu.h>
> >  #include <bsp/fdt.h>
> > diff --git a/bsps/arm/xilinx-zynqmp/console/console-config.c
> b/bsps/arm/xilinx-zynqmp/console/console-config.c
> > index b164db78a5..1712073c2c 100644
> > --- a/bsps/arm/xilinx-zynqmp/console/console-config.c
> > +++ b/bsps/arm/xilinx-zynqmp/console/console-config.c
> > @@ -33,6 +33,7 @@
> >  #include <rtems/console.h>
> >  #include <bsp/irq.h>
> >  #include <dev/serial/zynq-uart.h>
> > vc mailing list
> > vc at rtems.org
> > http://lists.rtems.org/mailman/listinfo/vc
URL: <http://lists.rtems.org/pipermail/devel/attachments/20230607/c0ad8d9e/attachment.htm>
