bsps/xilinx-zynqmp : Add BSP for RPU
Philip Kirkpatrick p.kirkpatrick at reflexaerospace.com
Wed Jun 14 08:08:20 UTC 2023
This patch adds support for running RTEMS on the RPU (cortex R5) cores of
the ZynqMP.  This is only a basic BSP and does not yet support the
following:
- SMP
- Cache
- MPU
Also, everything except for the startup and exception vectors runs out of
DRAM, which is slow without cache.  At some point in the future, I plan to
move some of the fast memory sections to ATCM and BTCM and enable cache.
Lastly, credit to Stanislav (s.pankevich at gmail.com, also on this mailing
list), for internal reviews and feedback.
The steps done to implement this BSP are as follows:
- to xilinx_zynqmp_ultra96 bsp (spec/build/bsps/arm/xilinx-zynqmp/*)
  - Added optprocunitapu.yml to pass C define ZYNQMP_PROC_UNIT_APU
- Copied xilinx_zynqmp_ultra96 bsp to xilinx_zynqmp_mercuryxu5_rpu in
spec/build/bsps/arm/xilinx-zynqmp-rpu/*
- In new BSP
  - changed optprocunitapu.yml to optprocunitrpu.yml to pass C define
ZYNQMP_PROC_UNIT_RPU
  - Removed all things regarding MMU, and SMP
  - Changed source: bsps/arm/shared/cache/cache-cp15.c to
bsps/shared/cache/nocache.c
  - Removed all other references to cache
  - Changed abi flags
  - Updated the linkcmds to remove MMU and cache sections.
  - Updated optint0len, optint0ori, optint1len, and optint1ori to target
ATCM and BTCM.
  - Updated linkcmds to place START and VECTOR regions in ATCM
- In BSP C sources
  - Used ZYNQMP_PROC_UNIT_APU and ZYNQMP_PROC_UNIT_RPU to enable/disable
MPU, SMP, and cache.
  - Used PROC_UNIT flags to control GIC address.
  - Added hook0 code for RPU code to make sure SCTLR[M, I, A, C, V] are
cleared
  - Created a timer driver for the Triple Timer Counter (TTC) module since
the RPU doesn't have an ARM generic timer
diff --git a/bsps/arm/xilinx-zynqmp/clock/clock-ttc.c
b/bsps/arm/xilinx-zynqmp/clock/clock-ttc.c
new file mode 100644
index 0000000000..dd0bc3a3c9
--- /dev/null
+++ b/bsps/arm/xilinx-zynqmp/clock/clock-ttc.c
@@ -0,0 +1,219 @@
+ * @file
+ * @ingroup RTEMSBSPsARMZynqMP
+ * @brief Triple Timer Counter clock functions definitions.
+ * SPDX-License-Identifier: BSD-2-Clause
+ * Copyright (C) 2023 Reflex Aerospace GmbH
+ * Written by Philip Kirkpatrick <p.kirkpatrick at reflexaerospace.com>
+ * are met:
+ * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS
IS"
+ * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO,
THE
+ * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR
PURPOSE
+ * ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF
THE
+#include <stdlib.h>
+#include <rtems.h>
+#include <bsp.h>
+#include <bsp/irq.h>
+#include <bsp/zynqmp.h>
+#include <bsp/xttcps_hw.h>
+#include <rtems/timecounter.h>
+static struct timecounter zynqmp_ttc_tc;
+#define TTC_REFERENCE_CLOCK 100000000
+/* This is defined in dev/clock/clockimpl.h */
+void Clock_isr(rtems_irq_hdl_param arg);
+static uint32_t irq_match_interval;
+static uint32_t zynqmp_ttc_get_timecount(struct timecounter *tc)
+  uint32_t time;
+  time = XTtcPs_ReadReg(ZYNQMP_TTC0, XTTCPS_COUNT_VALUE_OFFSET);
+  return time;
+ *  @brief Initialize the HW peripheral for clock driver
+ *  Clock driver is implemented by RTI module
+ * @retval Void
+static void zynqmp_ttc_clock_driver_support_initialize_hardware( void )
+  uint32_t microsec_per_tick;
+  uint16_t clock_ratio;
+  uint8_t  index;
+  uint32_t frequency;
+  uint32_t prescaler;
+  uint32_t tmp_reg_val;
+  microsec_per_tick = rtems_configuration_get_microseconds_per_tick();
+  /* Check the TTC is OFF before reconfiguring */
+  XTtcPs_WriteReg(ZYNQMP_TTC0, XTTCPS_CNT_CNTRL_OFFSET,
XTTCPS_CNT_CNTRL_DIS_MASK |
+        XTTCPS_CNT_CNTRL_EN_WAVE_MASK);  // Don't enable waveform output
(active low)
+  /* Prescaler value is 2^(N + 1) */
+  /* Divide down the clock as much as possible while still retaining a */
+  /* frequency that is an integer multiple of 1MHz.  This maximizes time
to */
+  /* overflow while minimizing rounding errors in 1us periods */
+  clock_ratio = TTC_REFERENCE_CLOCK / 1000000;
+  /* Search for the highest set bit.  This is effectively
min(log2(ratio))*/
+  for(index = sizeof(clock_ratio) * 8 - 1; index > 0; index--)
+    if((clock_ratio >> (index)) & 0x01)
+        break;
+  if(index == 0 && (clock_ratio & 0x01 == 0))
+    // No prescaler
+    frequency = TTC_REFERENCE_CLOCK;
+    XTtcPs_WriteReg(ZYNQMP_TTC0, XTTCPS_CLK_CNTRL_OFFSET, 0);
+  else
+    prescaler = index - 1;
+    frequency = TTC_REFERENCE_CLOCK / (1 << (prescaler + 1));
+        prescaler << XTTCPS_CLK_CNTRL_PS_VAL_SHIFT |
+        XTTCPS_CLK_CNTRL_PS_EN_MASK);
+  /* Max out the counter interval */
+  tmp_reg_val = XTTCPS_INTERVAL_VAL_MASK;
+  XTtcPs_WriteReg(ZYNQMP_TTC0, XTTCPS_INTERVAL_VAL_OFFSET, tmp_reg_val);
+  /* Setup match register to generate tick IRQ */
+  irq_match_interval = (uint32_t) ((frequency * microsec_per_tick) /
1000000);
+  XTtcPs_WriteReg(ZYNQMP_TTC0, XTTCPS_MATCH_0_OFFSET, irq_match_interval);
+  /* Clear interupts (clear on read) */
+  XTtcPs_ReadReg(ZYNQMP_TTC0, XTTCPS_ISR_OFFSET);
+  /* Enable interupt for match register */
+  XTtcPs_WriteReg(ZYNQMP_TTC0, XTTCPS_IER_OFFSET, XTTCPS_IXR_MATCH_0_MASK);
+  /* Configure, reset, and enable counter */
+        XTTCPS_CNT_CNTRL_EN_WAVE_MASK |  /* Don't enable waveform output
(active low) */
+        XTTCPS_CNT_CNTRL_RST_MASK |      /* Reset count and start counter
+        XTTCPS_CNT_CNTRL_MATCH_MASK      /* Enable match mode */
+        /* Increment mode */
+        /* Overflow mode */
+        /* Not disabled */
+  /* set timecounter */
+  zynqmp_ttc_tc.tc_get_timecount = zynqmp_ttc_get_timecount;
+  zynqmp_ttc_tc.tc_counter_mask = XTTCPS_COUNT_VALUE_MASK;
+  zynqmp_ttc_tc.tc_frequency = frequency;
+  zynqmp_ttc_tc.tc_quality = RTEMS_TIMECOUNTER_QUALITY_CLOCK_DRIVER;
+  rtems_timecounter_install(&zynqmp_ttc_tc);
+ * @brief Clears interrupt source
+ * @retval Void
+static uint32_t tick_miss = 0;
+static void zynqmp_ttc_clock_driver_support_at_tick( void )
+  uint32_t irq_flags;
+  uint32_t cval;
+  uint32_t now;
+  uint32_t delta;
+  /* Get and clear interupts (clear on read) */
+  irq_flags = XTtcPs_ReadReg(ZYNQMP_TTC0, XTTCPS_ISR_OFFSET);
+  if(irq_flags & XTTCPS_IXR_MATCH_0_MASK)
+    /* Update match */
+    cval = XTtcPs_ReadReg(ZYNQMP_TTC0, XTTCPS_MATCH_0_OFFSET);
+    /* Check that the match for the next tick is in the future */
+    /* If no, then set the match for one irq interval from now */
+    /*   This will have the effect that your timebase will slip but */
+    /*   won't hang waiting for the counter to wrap around. */
+    /* If this happens durring normal opteration, there is a problem */
+    /*   causing this interrupt to not be serviced quickly enough */
+    /* If this happens during debugging, that is normal and expected */
+    /*   becaue the TTC does NOT pause when the CPU is halted on a
breakpoint */
+    now = XTtcPs_ReadReg(ZYNQMP_TTC0, XTTCPS_COUNT_VALUE_OFFSET);
+    delta = now - cval;
+    if(delta > irq_match_interval)
+     cval = now;
+     tick_miss++;
+    cval += irq_match_interval;
+    XTtcPs_WriteReg(ZYNQMP_TTC0, XTTCPS_MATCH_0_OFFSET, cval);
+  /* Else, something is set up wrong, only match should be enabled */
+ * @brief registers RTI interrupt handler
+ * @param[in] Clock_isr new ISR handler
+ * @param[in] Old_ticker old ISR handler (unused and type broken)
+ * @retval Void
+static void zynqmp_ttc_clock_driver_support_install_isr(
+  rtems_isr_entry Clock_isr
+  rtems_status_code sc = RTEMS_SUCCESSFUL;
+  sc = rtems_interrupt_handler_install(
+    ZYNQMP_IRQ_TTC_0_0,
+    "Clock",
+    RTEMS_INTERRUPT_UNIQUE,
+    (rtems_interrupt_handler) Clock_isr,
+    NULL
+  if ( sc != RTEMS_SUCCESSFUL ) {
+    rtems_fatal_error_occurred(0xdeadbeef);
+#define Clock_driver_support_at_tick \
+                        zynqmp_ttc_clock_driver_support_at_tick
+#define Clock_driver_support_initialize_hardware \
+                        zynqmp_ttc_clock_driver_support_initialize_hardware
+#define Clock_driver_support_install_isr(Clock_isr) \
+              zynqmp_ttc_clock_driver_support_install_isr( Clock_isr )
+#include "../../../shared/dev/clock/clockimpl.h"
diff --git a/bsps/arm/xilinx-zynqmp/config/xilinx_zynqmp_rpu.inc
b/bsps/arm/xilinx-zynqmp/config/xilinx_zynqmp_rpu.inc
index 0000000000..f97f4d5018
--- /dev/null
+++ b/bsps/arm/xilinx-zynqmp/config/xilinx_zynqmp_rpu.inc
@@ -0,0 +1,10 @@
+include $(RTEMS_ROOT)/make/custom/default.cfg
+RTEMS_CPU = arm
+CPU_CFLAGS = -march=armv7-r -mthumb -mfpu=vfpv3-d16 -mfloat-abi=hard
+CFLAGS_OPTIMIZE_V ?= -O2 -g
+CFLAGS_OPTIMIZE_V += -ffunction-sections -fdata-sections
+LDFLAGS = -Wl,--gc-sections
diff --git a/bsps/arm/xilinx-zynqmp/include/bsp.h
b/bsps/arm/xilinx-zynqmp/include/bsp.h
index 9d33cf6134..d0b4b9d644 100644
--- a/bsps/arm/xilinx-zynqmp/include/bsp.h
+++ b/bsps/arm/xilinx-zynqmp/include/bsp.h
@@ -64,9 +64,17 @@
 extern "C" {
 #endif /* __cplusplus */
+#ifdef ZYNQMP_PROC_UNIT_APU
 #define BSP_ARM_GIC_CPUIF_BASE 0xf9020000
 #define BSP_ARM_GIC_DIST_BASE 0xf9010000
+#endif
+#ifdef ZYNQMP_PROC_UNIT_RPU
+#define BSP_ARM_GIC_CPUIF_BASE 0x00F9001000
+#define BSP_ARM_GIC_DIST_BASE 0xF9000000
+#endif
 #define BSP_ARM_A9MPCORE_SCU_BASE 0
diff --git a/bsps/arm/xilinx-zynqmp/include/bsp/irq.h
b/bsps/arm/xilinx-zynqmp/include/bsp/irq.h
index 9aae8168db..a8271bebb5 100644
--- a/bsps/arm/xilinx-zynqmp/include/bsp/irq.h
+++ b/bsps/arm/xilinx-zynqmp/include/bsp/irq.h
@@ -56,17 +56,32 @@ extern "C" {
  * @brief Interrupt Support
 /* PPIs */
 #define ZYNQMP_IRQ_HYP_TIMER 26
 #define ZYNQMP_IRQ_VIRT_TIMER 27
 #define ZYNQMP_IRQ_S_PHYS_TIMER 29
 #define ZYNQMP_IRQ_NS_PHYS_TIMER 30
+#endif
 /* SPIs */
 #define ZYNQMP_IRQ_UART_0 53
 #define ZYNQMP_IRQ_UART_1 54
+#define ZYNQMP_IRQ_TTC_0_0 68
+#define ZYNQMP_IRQ_TTC_0_1 69
+#define ZYNQMP_IRQ_TTC_0_2 70
+#define ZYNQMP_IRQ_TTC_1_0 71
+#define ZYNQMP_IRQ_TTC_1_1 72
+#define ZYNQMP_IRQ_TTC_1_2 73
+#define ZYNQMP_IRQ_TTC_2_0 74
+#define ZYNQMP_IRQ_TTC_2_1 75
+#define ZYNQMP_IRQ_TTC_2_2 76
+#define ZYNQMP_IRQ_TTC_3_0 77
+#define ZYNQMP_IRQ_TTC_3_1 78
+#define ZYNQMP_IRQ_TTC_3_2 79
 #define BSP_INTERRUPT_VECTOR_COUNT 188
diff --git a/bsps/arm/xilinx-zynqmp/include/bsp/xttcps_hw.h
b/bsps/arm/xilinx-zynqmp/include/bsp/xttcps_hw.h
index 0000000000..ba0d559b07
--- /dev/null
+++ b/bsps/arm/xilinx-zynqmp/include/bsp/xttcps_hw.h
@@ -0,0 +1,223 @@
+* Copyright (C) 2010 - 2021 Xilinx, Inc.  All rights reserved.
+* SPDX-License-Identifier: MIT
+* @file xttcps_hw.h
+* @addtogroup ttcps_v3_14
+* This file defines the hardware interface to one of the three timer
counters
+* in the Ps block.
+* <pre>
+* MODIFICATION HISTORY:
+* Ver   Who    Date     Changes
+* 1.00a drg/jz 01/21/10 First release
+* 3.00  kvn    02/13/15 Modified code for MISRA-C:2012 compliance.
+* 3.5   srm    10/06/17 Updated XTTCPS_COUNT_VALUE_MASK,
+*                       XTTCPS_INTERVAL_VAL_MASK, XTTCPS_MATCH_MASK macros
to
+*                       mask 16 bit values for zynq and 32 bit values for
+*                       zynq ultrascale+mpsoc "
+* </pre>
+#ifndef XTTCPS_HW_H /* prevent circular inclusions */
+#define XTTCPS_HW_H /* by using protection macros */
+#ifdef __cplusplus
+extern "C" {
+#endif
+/***************************** Include Files
+#ifndef __rtems__
+#include "xil_types.h"
+#include "xil_assert.h"
+#include "xil_io.h"
+#else
+static inline u32 Xil_In32(UINTPTR Addr)
+ return *(volatile u32 *) Addr;
+static inline void Xil_Out32(UINTPTR Addr, u32 Value)
+ volatile u32 *LocalAddr = (volatile u32 *)Addr;
+ *LocalAddr = Value;
+#endif /* __rtems__ */
+/************************** Constant Definitions
+ * Flag for a9 processor
+#if 0
+ #if !defined (ARMR5) && !defined (__aarch64__) && !defined (ARMA53_32)
+ #define ARMA9
+ #endif
+#endif
+/** @name Register Map
+ * Register offsets from the base address of the device.
+#define XTTCPS_CLK_CNTRL_OFFSET 0x00000000U  /**< Clock Control Register */
+#define XTTCPS_CNT_CNTRL_OFFSET 0x0000000CU  /**< Counter Control
Register*/
+#define XTTCPS_COUNT_VALUE_OFFSET 0x00000018U  /**< Current Counter Value
+#define XTTCPS_INTERVAL_VAL_OFFSET 0x00000024U  /**< Interval Count Value
+#define XTTCPS_MATCH_0_OFFSET 0x00000030U  /**< Match 1 value */
+#define XTTCPS_MATCH_1_OFFSET 0x0000003CU  /**< Match 2 value */
+#define XTTCPS_MATCH_2_OFFSET 0x00000048U  /**< Match 3 value */
+#define XTTCPS_ISR_OFFSET 0x00000054U  /**< Interrupt Status Register */
+#define XTTCPS_IER_OFFSET 0x00000060U  /**< Interrupt Enable Register */
+/** @name Clock Control Register
+ * Clock Control Register definitions
+#define XTTCPS_CLK_CNTRL_PS_EN_MASK 0x00000001U  /**< Prescale enable */
+#define XTTCPS_CLK_CNTRL_PS_VAL_MASK 0x0000001EU  /**< Prescale value */
+#define XTTCPS_CLK_CNTRL_PS_VAL_SHIFT 1U  /**< Prescale shift */
+#define XTTCPS_CLK_CNTRL_PS_DISABLE 16U  /**< Prescale disable */
+#define XTTCPS_CLK_CNTRL_SRC_MASK 0x00000020U  /**< Clock source */
+#define XTTCPS_CLK_CNTRL_EXT_EDGE_MASK 0x00000040U  /**< External Clock
edge */
+/** @name Counter Control Register
+ * Counter Control Register definitions
+#define XTTCPS_CNT_CNTRL_DIS_MASK 0x00000001U /**< Disable the counter */
+#define XTTCPS_CNT_CNTRL_INT_MASK 0x00000002U /**< Interval mode */
+#define XTTCPS_CNT_CNTRL_DECR_MASK 0x00000004U /**< Decrement mode */
+#define XTTCPS_CNT_CNTRL_MATCH_MASK 0x00000008U /**< Match mode */
+#define XTTCPS_CNT_CNTRL_RST_MASK 0x00000010U /**< Reset counter */
+#define XTTCPS_CNT_CNTRL_EN_WAVE_MASK 0x00000020U /**< Enable waveform */
+#define XTTCPS_CNT_CNTRL_POL_WAVE_MASK 0x00000040U /**< Waveform polarity
+#define XTTCPS_CNT_CNTRL_RESET_VALUE 0x00000021U /**< Reset value */
+/** @name Current Counter Value Register
+ * Current Counter Value Register definitions
+#if defined(ARMA9)
+#define XTTCPS_COUNT_VALUE_MASK 0x0000FFFFU /**< 16-bit counter value */
+#else
+#define XTTCPS_COUNT_VALUE_MASK 0xFFFFFFFFU /**< 32-bit counter value */
+#endif
+/** @name Interval Value Register
+ * Interval Value Register is the maximum value the counter will count up
or
+ * down to.
+#if defined(ARMA9)
+#define XTTCPS_INTERVAL_VAL_MASK (u32)(0x0000FFFF) /**< 16-bit Interval
value*/
+#else
+#define XTTCPS_INTERVAL_VAL_MASK (u32)(0xFFFFFFFF) /**< 32-bit Interval
value*/
+#endif
+/** @name Match Registers
+ * Definitions for Match registers, each timer counter has three match
+ * registers.
+#if defined(ARMA9)
+#define XTTCPS_MATCH_MASK 0x0000FFFFU /**< 16-bit Match value */
+#else
+#define XTTCPS_MATCH_MASK 0xFFFFFFFFU /**< 32-bit Match value */
+#endif
+#define XTTCPS_NUM_MATCH_REG 3U /**< Num of Match reg */
+/** @name Interrupt Registers
+ * Following register bit mask is for all interrupt registers.
+#define XTTCPS_IXR_INTERVAL_MASK 0x00000001U  /**< Interval Interrupt */
+#define XTTCPS_IXR_MATCH_0_MASK 0x00000002U  /**< Match 1 Interrupt */
+#define XTTCPS_IXR_MATCH_1_MASK 0x00000004U  /**< Match 2 Interrupt */
+#define XTTCPS_IXR_MATCH_2_MASK 0x00000008U  /**< Match 3 Interrupt */
+#define XTTCPS_IXR_CNT_OVR_MASK 0x00000010U  /**< Counter Overflow */
+#define XTTCPS_IXR_ALL_MASK 0x0000001FU  /**< All valid Interrupts */
+/***************** Macros (Inline Functions) Definitions
+* Read the given Timer Counter register.
+* @param BaseAddress is the base address of the timer counter device.
+* @param RegOffset is the register offset to be read
+* @return The 32-bit value of the register
+* @note C-style signature:
+* u32 XTtcPs_ReadReg(u32 BaseAddress, u32 RegOffset)
+#define XTtcPs_ReadReg(BaseAddress, RegOffset) \
+    (Xil_In32((BaseAddress) + (u32)(RegOffset)))
+* Write the given Timer Counter register.
+* @param RegOffset is the register offset to be written
+* @param Data is the 32-bit value to write to the register
+* @return None.
+* void XTtcPs_WriteReg(XTtcPs BaseAddress, u32 RegOffset,
+* u32 Data)
+#define XTtcPs_WriteReg(BaseAddress, RegOffset, Data) \
+    (Xil_Out32((BaseAddress) + (u32)(RegOffset), (u32)(Data)))
+* Calculate a match register offset using the Match Register index.
+* @param MatchIndex is the 0-2 value of the match register
+* @return MATCH_N_OFFSET.
+* u32 XTtcPs_Match_N_Offset(u8 MatchIndex)
+#define XTtcPs_Match_N_Offset(MatchIndex) \
+ ((u32)XTTCPS_MATCH_0_OFFSET + ((u32)(12U) * (u32)(MatchIndex)))
+/************************** Function Prototypes
+/************************** Variable Definitions
+#ifdef __cplusplus
+#endif
+#endif /* end of protection macro */
diff --git a/bsps/arm/xilinx-zynqmp/include/bsp/zynqmp.h
b/bsps/arm/xilinx-zynqmp/include/bsp/zynqmp.h
index 0000000000..7a48810490
--- /dev/null
+++ b/bsps/arm/xilinx-zynqmp/include/bsp/zynqmp.h
@@ -0,0 +1,92 @@
+ * are met:
IS"
THE
PURPOSE
THE
+#ifndef LIBBSP_ARM_ZYNQMP
+#define LIBBSP_ARM_ZYNQMP
+/* Data derived from
https://docs.xilinx.com/r/en-US/ug1085-zynq-ultrascale-trm/PS-I/O-Peripherals-Registers
+/* LPD IO Peripherals */
+#define ZYNQMP_UART0 (0xFF000000)
+#define ZYNQMP_UART1 (0xFF010000)
+#define ZYNQMP_I2C0 (0xFF020000)
+#define ZYNQMP_I2C1 (0xFF030000)
+#define ZYNQMP_SPI0 (0xFF040000)
+#define ZYNQMP_SPI1 (0xFF050000)
+#define ZYNQMP_CAN0 (0xFF060000)
+#define ZYNQMP_CAN1 (0xFF070000)
+#define ZYNQMP_GPIO (0xFF0A0000)
+#define ZYNQMP_GEM0 (0xFF0B0000)
+#define ZYNQMP_GEM1 (0xFF0C0000)
+#define ZYNQMP_GEM2 (0xFF0D0000)
+#define ZYNQMP_GEM3 (0xFF0E0000)
+#define ZYNQMP_QSPI (0xFF0F0000)
+#define ZYNQMP_NAND (0xFF100000)
+#define ZYNQMP_SD0 (0xFF160000)
+#define ZYNQMP_SD1 (0xFF170000)
+#define ZYNQMP_IPI_MSG (0xFF990000)
+#define ZYNQMP_USB0 (0xFF9D0000)
+#define ZYNQMP_USB1 (0xFF9E0000)
+#define ZYNQMP_AMS (0xFFA50000)
+#define ZYNQMP_PSSYSMON (0xFFA50800)
+#define ZYNQMP_PLSYSMON (0xFFA50C00)
+#define ZYNQMP_CSU_SWDT (0xFFCB0000)
+/* FPD IO Peripherals */
+#define ZYNQMP_SATA (0xFD0C0000)
+#define ZYNQMP_PCIE (0xFD0E0000)
+#define ZYNQMP_PCIE_IN (0xFD0E0800)
+#define ZYNQMP_PCIE_EG (0xFD0E0C00)
+#define ZYNQMP_PCIE_DMA (0xFD0F0000)
+#define ZYNQMP_SIOU (0xFD3D0000)
+#define ZYNQMP_GTR (0xFD400000)
+#define ZYNQMP_PCIE_ATTR (0xFD480000)
+#define ZYNQMP_DP (0xFD4A0000)
+#define ZYNQMP_GPU (0xFD4B0000)
+#define ZYNQMP_DP_DMA (0xFD4C0000)
+/* LPD System Registers */
+#define ZYNQMP_IPI (0xFF300000)
+#define ZYNQMP_TTC0 (0xFF110000)
+#define ZYNQMP_TTC1 (0xFF120000)
+#define ZYNQMP_TTC2 (0xFF130000)
+#define ZYNQMP_TTC3 (0xFF140000)
+#define ZYNQMP_LPD_SWDT (0xFF150000)
+#define ZYNQMP_XPPU (0xFF980000)
+#define ZYNQMP_XPPU_SINK (0xFF9C0000)
+#define ZYNQMP_PL_LPD (0xFF9B0000)
+#define ZYNQMP_OCM (0xFFA00000)
+#define ZYNQMP_LPD_FPD (0xFFA10000)
+#define ZYNQMP_RTC (0xFFA60000)
+#define ZYNQMP_OCM_XMPU (0xFFA70000)
+#define ZYNQMP_LPD_DMA (0xFFA80000)
+#define ZYNQMP_CSU_DMA (0xFFC80000)
+#define ZYNQMP_CSU (0xFFCA0000)
+#define ZYNQMP_BBRAM (0xFFCD0000)
+#endif /* LIBBSP_ARM_ZYNQMP */
diff --git a/bsps/arm/xilinx-zynqmp/start/bspsmp.c
b/bsps/arm/xilinx-zynqmp/start/bspsmp.c
index 28a4b6d54d..4129e6dd59 100644
--- a/bsps/arm/xilinx-zynqmp/start/bspsmp.c
+++ b/bsps/arm/xilinx-zynqmp/start/bspsmp.c
@@ -34,6 +34,7 @@
 #include <bsp/start.h>
 bool _CPU_SMP_Start_processor(uint32_t cpu_index)
@@ -55,3 +56,11 @@ bool _CPU_SMP_Start_processor(uint32_t cpu_index)
   return _Per_CPU_State_wait_for_non_initial_state(cpu_index, 0);
+ * SMP not currently supported on RPU
+#endif
\ No newline at end of file
diff --git a/bsps/arm/xilinx-zynqmp/start/bspstart.c
b/bsps/arm/xilinx-zynqmp/start/bspstart.c
index fe04ef4f8f..2825653557 100644
--- a/bsps/arm/xilinx-zynqmp/start/bspstart.c
+++ b/bsps/arm/xilinx-zynqmp/start/bspstart.c
@@ -38,6 +38,7 @@
 #include <libcpu/arm-cp15.h>
 void arm_generic_timer_get_config(uint32_t *frequency, uint32_t *irq)
 #ifdef ARM_GENERIC_TIMER_FREQ
@@ -53,12 +54,15 @@ void arm_generic_timer_get_config(uint32_t *frequency,
uint32_t *irq)
   *irq = ZYNQMP_IRQ_NS_PHYS_TIMER;
 #endif
+#endif
 void bsp_start(void)
   bsp_interrupt_initialize();
   rtems_cache_coherent_add_area(
     bsp_section_nocacheheap_begin,
     (uintptr_t) bsp_section_nocacheheap_size
+#endif
diff --git a/bsps/arm/xilinx-zynqmp/start/bspstarthooks.c
b/bsps/arm/xilinx-zynqmp/start/bspstarthooks.c
index ef76563a38..07f97fb5fd 100644
--- a/bsps/arm/xilinx-zynqmp/start/bspstarthooks.c
+++ b/bsps/arm/xilinx-zynqmp/start/bspstarthooks.c
@@ -35,12 +35,34 @@
 BSP_START_TEXT_SECTION void bsp_start_hook_0(void)
-  /* Nothing to do */
+  #ifdef ZYNQMP_PROC_UNIT_RPU
+     * On reset, V will be set.  This points the exceptions to the FSBL's
vectors.  The FSBL
+     * should clear this bit before booting RTEMS but in some debugging
+     * configurations the bit may not be.  The other bits should already
be clear
+     * on reset.  Since the correct settings in these bits are critical,
+ * make sure SCTLR[M, I, A, C, V] are cleared.  Afterwards, exceptions are
+ * handled by RTEMS.
+     * Note 1: The APU also does these steps in start.S in _start in the
#if block at line 401
+     * Note 2: Not all Arm R cores need this (like the TMS570).  So, this
probably should
+     *         be in this hook and not in start.S
+    __asm__ volatile(
+      "mrc p15, 0, r0, c1, c0, 0 \n"
+      "bic r1, r0, #0x2800 \n"
+      "bic r1, r1, #0x7 \n"
+      "mcr p15, 0, r1, c1, c0, 0 \n"
+  #endif
 BSP_START_TEXT_SECTION void bsp_start_hook_1(void)
   bsp_start_copy_sections();
   zynqmp_setup_mmu_and_cache();
+#endif
   bsp_start_clear_bss();
diff --git a/spec/build/bsps/arm/xilinx-zynqmp-rpu/abi.yml
b/spec/build/bsps/arm/xilinx-zynqmp-rpu/abi.yml
index 0000000000..829e9c9297
--- /dev/null
+++ b/spec/build/bsps/arm/xilinx-zynqmp-rpu/abi.yml
@@ -0,0 +1,21 @@
+SPDX-License-Identifier: CC-BY-SA-4.0 OR BSD-2-Clause
+actions:
+- get-string: null
+- split: null
+- env-append: null
+build-type: option
+copyrights:
+- Copyright (C) 2023 Reflex Aerospace GmbH (
https://www.reflexaerospace.com/)
+default:
+- enabled-by: true
+  value:
+  - -march=armv7-r
+  - -mthumb
+  - -mfpu=vfpv3-d16
+  - -mfloat-abi=hard
+description: |
+  ABI flags
+enabled-by: true
+links: []
+name: ABI_FLAGS
+type: build
diff --git a/spec/build/bsps/arm/xilinx-zynqmp-rpu/bspmercureyxu5.yml
b/spec/build/bsps/arm/xilinx-zynqmp-rpu/bspmercureyxu5.yml
index 0000000000..1b8b16796a
--- /dev/null
+++ b/spec/build/bsps/arm/xilinx-zynqmp-rpu/bspmercureyxu5.yml
@@ -0,0 +1,94 @@
+arch: arm
+bsp: xilinx_zynqmp_mercuryxu5_rpu
+build-type: bsp
+cflags: []
+copyrights:
+cppflags: []
+enabled-by: true
+family: xilinx-zynqmp
+includes:
+- bsps/include/xil/
+install:
+- destination: ${BSP_INCLUDEDIR}
+  source:
+  - bsps/arm/xilinx-zynqmp/include/bsp.h
+  - bsps/include/xil/xil_types.h
+  - bsps/include/xil/xil_assert.h
+  - bsps/include/xil/xil_io.h
+- destination: ${BSP_INCLUDEDIR}/bsp
+  source:
+  - bsps/arm/xilinx-zynqmp/include/bsp/irq.h
+  - bsps/arm/xilinx-zynqmp/include/bsp/xttcps_hw.h
+  - bsps/arm/xilinx-zynqmp/include/bsp/zynqmp.h
+links:
+- role: build-dependency
+  uid: ../grp
+  uid: ../start
+  uid: abi
+  uid: optclkfastidle
+  uid: optclkuart
+  uid: optconirq
+  uid: ../../optconminor
+  uid: optint0len
+  uid: optint0ori
+  uid: optint1len
+  uid: optint1ori
+  uid: optramlen
+  uid: optramori
+  uid: optresetvec
+  uid: optprocunitrpu
+  uid: ../../obj
+  uid: ../../objirq
+  uid: ../../objdevserialzynq
+  uid: ../../objdevspizynq
+  uid: ../../objdevspixil
+  uid: ../../objmem
+  uid: ../../opto0
+  uid: linkcmds
+  uid: ../../bspopts
+source:
+- bsps/shared/cache/nocache.c
+- bsps/arm/shared/cp15/arm-cp15-set-exception-handler.c
+- bsps/arm/shared/cp15/arm-cp15-set-ttb-entries.c
+- bsps/arm/shared/start/bsp-start-memcpy.S
+- bsps/arm/xilinx-zynqmp/console/console-config.c
+- bsps/arm/xilinx-zynqmp/start/bspreset.c
+- bsps/arm/xilinx-zynqmp/start/bspstart.c
+- bsps/arm/xilinx-zynqmp/start/bspstarthooks.c
+- bsps/arm/xilinx-zynqmp/clock/clock-ttc.c
+- bsps/shared/dev/btimer/btimer-cpucounter.c
+- bsps/shared/dev/getentropy/getentropy-cpucounter.c
+- bsps/shared/dev/irq/arm-gicv2.c
+- bsps/shared/dev/irq/arm-gicv2-zynqmp.c
+- bsps/shared/dev/serial/console-termios.c
+- bsps/shared/irq/irq-default-handler.c
+- bsps/shared/start/bspfatal-default.c
+- bsps/shared/start/gettargethash-default.c
+- bsps/shared/start/sbrk.c
+- bsps/shared/start/stackalloc.c
+type: build
diff --git a/spec/build/bsps/arm/xilinx-zynqmp-rpu/linkcmds.yml
b/spec/build/bsps/arm/xilinx-zynqmp-rpu/linkcmds.yml
index 0000000000..6208dc4b12
--- /dev/null
+++ b/spec/build/bsps/arm/xilinx-zynqmp-rpu/linkcmds.yml
@@ -0,0 +1,41 @@
+build-type: config-file
+content: |
+  MEMORY {
+    RAM_INT_0 : ORIGIN = ${ZYNQMP_RAM_INT_0_ORIGIN:#010x}, LENGTH =
${ZYNQMP_RAM_INT_0_LENGTH:#010x}
+    RAM_INT_1 : ORIGIN = ${ZYNQMP_RAM_INT_1_ORIGIN:#010x}, LENGTH =
${ZYNQMP_RAM_INT_1_LENGTH:#010x}
+    RAM       : ORIGIN = ${ZYNQMP_RAM_ORIGIN:#010x}, LENGTH =
${ZYNQMP_RAM_LENGTH:#010x} - ${ZYNQMP_RAM_ORIGIN:#010x}
+  REGION_ALIAS ("REGION_START",          RAM_INT_0);
+  REGION_ALIAS ("REGION_VECTOR",         RAM_INT_0);
+  REGION_ALIAS ("REGION_TEXT",           RAM);
+  REGION_ALIAS ("REGION_TEXT_LOAD",      RAM);
+  REGION_ALIAS ("REGION_RODATA",         RAM);
+  REGION_ALIAS ("REGION_RODATA_LOAD",    RAM);
+  REGION_ALIAS ("REGION_DATA",           RAM);
+  REGION_ALIAS ("REGION_DATA_LOAD",      RAM);
+  REGION_ALIAS ("REGION_FAST_TEXT",      RAM);
+  REGION_ALIAS ("REGION_FAST_TEXT_LOAD", RAM);
+  REGION_ALIAS ("REGION_FAST_DATA",      RAM);
+  REGION_ALIAS ("REGION_FAST_DATA_LOAD", RAM);
+  REGION_ALIAS ("REGION_BSS",            RAM);
+  REGION_ALIAS ("REGION_WORK",           RAM);
+  REGION_ALIAS ("REGION_STACK",          RAM);
+  REGION_ALIAS ("REGION_NOCACHE",        RAM);
+  REGION_ALIAS ("REGION_NOCACHE_LOAD",   RAM);
+  bsp_stack_abt_size = DEFINED (bsp_stack_abt_size) ? bsp_stack_abt_size :
1024;
+  bsp_section_rwbarrier_align = DEFINED (bsp_section_rwbarrier_align) ?
bsp_section_rwbarrier_align : 1M;
+  bsp_vector_table_in_start_section = 1;
+  INCLUDE linkcmds.armv4
+copyrights:
+enabled-by: true
+install-path: ${BSP_LIBDIR}
+links: []
+target: linkcmds
+type: build
diff --git a/spec/build/bsps/arm/xilinx-zynqmp-rpu/optclkfastidle.yml
b/spec/build/bsps/arm/xilinx-zynqmp-rpu/optclkfastidle.yml
index 0000000000..e303a8bf9f
--- /dev/null
+++ b/spec/build/bsps/arm/xilinx-zynqmp-rpu/optclkfastidle.yml
@@ -0,0 +1,21 @@
+actions:
+- get-boolean: null
+- define-condition: null
+build-type: option
+copyrights:
+- Copyright (C) 2020 embedded brains GmbH (http://www.embedded-brains.de)
+default:
+- enabled-by:
+  - arm/lm3s6965_qemu
+  - arm/realview_pbx_a9_qemu
+  - arm/xilinx_zynq_a9_qemu
+  value: true
+- enabled-by: true
+  value: false
+description: |
+  This sets a mode where the time runs as fast as possible when a clock
ISR occurs while the IDLE thread is executing.  This can significantly
reduce simulation times.
+enabled-by: true
+links: []
+name: CLOCK_DRIVER_USE_FAST_IDLE
+type: build
diff --git a/spec/build/bsps/arm/xilinx-zynqmp-rpu/optclkuart.yml
b/spec/build/bsps/arm/xilinx-zynqmp-rpu/optclkuart.yml
index 0000000000..77c8f30fff
--- /dev/null
+++ b/spec/build/bsps/arm/xilinx-zynqmp-rpu/optclkuart.yml
@@ -0,0 +1,17 @@
+actions:
+- get-integer: null
+- define: null
+build-type: option
+copyrights:
+default:
+- enabled-by: true
+  value: 100000000
+description: |
+  Zynq UART clock frequency in Hz
+enabled-by: true
+format: '{}'
+links: []
+name: ZYNQ_CLOCK_UART
+type: build
diff --git a/spec/build/bsps/arm/xilinx-zynqmp-rpu/optconirq.yml
b/spec/build/bsps/arm/xilinx-zynqmp-rpu/optconirq.yml
index 0000000000..ea13fa4561
--- /dev/null
+++ b/spec/build/bsps/arm/xilinx-zynqmp-rpu/optconirq.yml
@@ -0,0 +1,16 @@
+actions:
+build-type: option
+copyrights:
+default:
+- enabled-by: true
+  value: true
+description: |
+  use interrupt driven mode for console devices (used by default)
+enabled-by: true
+links: []
+name: ZYNQ_CONSOLE_USE_INTERRUPTS
+type: build
diff --git a/spec/build/bsps/arm/xilinx-zynqmp-rpu/optint0len.yml
b/spec/build/bsps/arm/xilinx-zynqmp-rpu/optint0len.yml
index 0000000000..774d2c9269
--- /dev/null
+++ b/spec/build/bsps/arm/xilinx-zynqmp-rpu/optint0len.yml
@@ -0,0 +1,18 @@
+actions:
+- assert-uint32: null
+- env-assign: null
+- format-and-define: null
+build-type: option
+copyrights:
+default:
+- enabled-by: true
+  value: 0x00010000
+description: ''
+enabled-by: true
+format: '{:#010x}'
+links: []
+name: ZYNQMP_RAM_INT_0_LENGTH
+type: build
diff --git a/spec/build/bsps/arm/xilinx-zynqmp-rpu/optint0ori.yml
b/spec/build/bsps/arm/xilinx-zynqmp-rpu/optint0ori.yml
index 0000000000..3fa03d3129
--- /dev/null
+++ b/spec/build/bsps/arm/xilinx-zynqmp-rpu/optint0ori.yml
@@ -0,0 +1,18 @@
+actions:
+- env-assign: null
+build-type: option
+copyrights:
+default:
+- enabled-by: true
+  value: 0x00000000
+description: ''
+enabled-by: true
+format: '{:#010x}'
+links: []
+name: ZYNQMP_RAM_INT_0_ORIGIN
+type: build
diff --git a/spec/build/bsps/arm/xilinx-zynqmp-rpu/optint1len.yml
b/spec/build/bsps/arm/xilinx-zynqmp-rpu/optint1len.yml
index 0000000000..f179142ed4
--- /dev/null
+++ b/spec/build/bsps/arm/xilinx-zynqmp-rpu/optint1len.yml
@@ -0,0 +1,18 @@
+actions:
+- env-assign: null
+build-type: option
+copyrights:
+default:
+- enabled-by: true
+  value: 0x00010000
+description: ''
+enabled-by: true
+format: '{:#010x}'
+links: []
+name: ZYNQMP_RAM_INT_1_LENGTH
+type: build
diff --git a/spec/build/bsps/arm/xilinx-zynqmp-rpu/optint1ori.yml
b/spec/build/bsps/arm/xilinx-zynqmp-rpu/optint1ori.yml
index 0000000000..37bbf4fcd0
--- /dev/null
+++ b/spec/build/bsps/arm/xilinx-zynqmp-rpu/optint1ori.yml
@@ -0,0 +1,18 @@
+actions:
+- env-assign: null
+build-type: option
+copyrights:
+default:
+- enabled-by: true
+  value: 0x00020000
+description: ''
+enabled-by: true
+format: '{:#010x}'
+links: []
+name: ZYNQMP_RAM_INT_1_ORIGIN
+type: build
diff --git a/spec/build/bsps/arm/xilinx-zynqmp-rpu/optprocunitrpu.yml
b/spec/build/bsps/arm/xilinx-zynqmp-rpu/optprocunitrpu.yml
index 0000000000..9298808b2a
--- /dev/null
+++ b/spec/build/bsps/arm/xilinx-zynqmp-rpu/optprocunitrpu.yml
@@ -0,0 +1,17 @@
+actions:
+build-type: option
+copyrights:
+default:
+- enabled-by: true
+  value: true
+description: |
+  Sets the target processing unit to the RPU (R5F) cores.
+enabled-by: true
+format: '{}'
+links: []
+name: ZYNQMP_PROC_UNIT_RPU
+type: build
diff --git a/spec/build/bsps/arm/xilinx-zynqmp-rpu/optramlen.yml
b/spec/build/bsps/arm/xilinx-zynqmp-rpu/optramlen.yml
index 0000000000..5cb5e805cf
--- /dev/null
+++ b/spec/build/bsps/arm/xilinx-zynqmp-rpu/optramlen.yml
@@ -0,0 +1,21 @@
+actions:
+- env-assign: null
+build-type: option
+copyrights:
+default:
+- enabled-by: arm/xilinx_zynqmp_ultra96
+  value: 0x80000000
+- enabled-by: true
+  value: 0x10000000
+description: |
+  override a BSP's default RAM length
+enabled-by: true
+format: '{:#010x}'
+links: []
+name: ZYNQMP_RAM_LENGTH
+type: build
diff --git a/spec/build/bsps/arm/xilinx-zynqmp-rpu/optramori.yml
b/spec/build/bsps/arm/xilinx-zynqmp-rpu/optramori.yml
index 0000000000..6269b662e0
--- /dev/null
+++ b/spec/build/bsps/arm/xilinx-zynqmp-rpu/optramori.yml
@@ -0,0 +1,19 @@
+actions:
+- assert-aligned: 1048576
+- env-assign: null
+build-type: option
+copyrights:
+default:
+- enabled-by: true
+  value: 0x00100000
+description: ''
+enabled-by: true
+format: '{:#010x}'
+links: []
+name: ZYNQMP_RAM_ORIGIN
+type: build
diff --git a/spec/build/bsps/arm/xilinx-zynqmp-rpu/optresetvec.yml
b/spec/build/bsps/arm/xilinx-zynqmp-rpu/optresetvec.yml
index 0000000000..bac5c79627
--- /dev/null
+++ b/spec/build/bsps/arm/xilinx-zynqmp-rpu/optresetvec.yml
@@ -0,0 +1,16 @@
+actions:
+build-type: option
+copyrights:
+default:
+- enabled-by: true
+  value: false
+description: |
+  reset vector address for BSP start
+enabled-by: true
+links: []
+name: BSP_START_RESET_VECTOR
+type: build
diff --git a/spec/build/bsps/arm/xilinx-zynqmp/bspxilinxzynqmp.yml
b/spec/build/bsps/arm/xilinx-zynqmp/bspxilinxzynqmp.yml
index 216cc88360..f14efc2957 100644
--- a/spec/build/bsps/arm/xilinx-zynqmp/bspxilinxzynqmp.yml
+++ b/spec/build/bsps/arm/xilinx-zynqmp/bspxilinxzynqmp.yml
@@ -62,6 +62,8 @@ links:
   uid: optramori
   uid: optresetvec
+  uid: optprocunitapu
   uid: ../../obj
diff --git a/spec/build/bsps/arm/xilinx-zynqmp/optprocunitapu.yml
b/spec/build/bsps/arm/xilinx-zynqmp/optprocunitapu.yml
index 0000000000..6040891123
--- /dev/null
+++ b/spec/build/bsps/arm/xilinx-zynqmp/optprocunitapu.yml
@@ -0,0 +1,17 @@
+actions:
+build-type: option
+copyrights:
+default:
+- enabled-by: true
+  value: true
+description: |
+  Sets the target processing unit to the APU (A53) cores.
+enabled-by: true
+format: '{}'
+links: []
+name: ZYNQMP_PROC_UNIT_APU
+type: build
URL: <http://lists.rtems.org/pipermail/devel/attachments/20230614/5d378b7d/attachment-0001.htm>
