[PATCH v2 14/32] bsp/leon3: Add LEON3_APBUART_BASE
Sebastian Huber
Fri Jun 16 06:01:11 UTC 2023
bsps/sparc/leon3/console/printk_support.c | 37 +++++++++++++++----
bsps/sparc/leon3/include/bsp/leon3.h | 5 +++
bsps/sparc/leon3/include/leon.h | 2 +
spec/build/bsps/sparc/leon3/grp.yml | 2 +
.../build/bsps/sparc/leon3/optapbuartbase.yml | 20 ++++++++++
5 files changed, 58 insertions(+), 8 deletions(-)
create mode 100644 spec/build/bsps/sparc/leon3/optapbuartbase.yml
diff --git a/bsps/sparc/leon3/console/printk_support.c b/bsps/sparc/leon3/console/printk_support.c
index cb77c66a96..9e260d2eac 100644
--- a/bsps/sparc/leon3/console/printk_support.c
+++ b/bsps/sparc/leon3/console/printk_support.c
@@ -38,20 +38,27 @@
#include <bsp/leon3.h>
#include <rtems/bspIo.h>
#include <rtems/sysinit.h>
-#include <rtems/score/thread.h>
#include <grlib/apbuart.h>
#include <grlib/io.h>
+#if !defined(LEON3_APBUART_BASE)
#include <grlib/ambapp.h>
int leon3_debug_uart_index __attribute__((weak)) = 0;
apbuart *leon3_debug_uart = NULL;
+#endif
static void bsp_debug_uart_init(void);
-static void bsp_debug_uart_discard(char c)
+static void apbuart_enable_receive_and_transmit(apbuart *regs)
- (void) c;
+ uint32_t ctrl;
+ ctrl = grlib_load_32(®s->ctrl);
+ ctrl |= APBUART_CTRL_RE | APBUART_CTRL_TE;
+ grlib_store_32(®s->ctrl, ctrl);
+ grlib_store_32(®s->status, 0);
static void bsp_debug_uart_output_char(char c)
@@ -71,6 +78,22 @@ static void bsp_debug_uart_pre_init_out(char c)
(*BSP_output_char)(c);
+#if defined(LEON3_APBUART_BASE)
+static void bsp_debug_uart_init(void)
+ apbuart_enable_receive_and_transmit(leon3_debug_uart);
+ BSP_poll_char = bsp_debug_uart_poll_char;
+ BSP_output_char = bsp_debug_uart_output_char;
+#else /* !LEON3_APBUART_BASE */
+static void bsp_debug_uart_discard(char c)
+ (void) c;
/* Initialize the BSP system debug console layer. It will scan AMBA Plu&Play
* for a debug APBUART and enable RX/TX for that UART.
@@ -108,7 +131,6 @@ static void bsp_debug_uart_init(void)
ambapp_find_by_idx, (void *)&i);
if (adev != NULL) {
struct ambapp_apb_info *apb;
- uint32_t ctrl;
* Found a matching debug console, initialize debug UART if present for
@@ -116,16 +138,15 @@ static void bsp_debug_uart_init(void)
apb = (struct ambapp_apb_info *)adev->devinfo;
leon3_debug_uart = (apbuart *)apb->start;
- ctrl = grlib_load_32(&leon3_debug_uart->ctrl);
- ctrl |= APBUART_CTRL_RE | APBUART_CTRL_TE;
- grlib_store_32(&leon3_debug_uart->ctrl, ctrl);
- grlib_store_32(&leon3_debug_uart->status, 0);
+#endif /* LEON3_APBUART_BASE */
RTEMS_SYSINIT_ITEM(
bsp_debug_uart_init,
RTEMS_SYSINIT_BSP_START,
diff --git a/bsps/sparc/leon3/include/bsp/leon3.h b/bsps/sparc/leon3/include/bsp/leon3.h
index aa3898e530..1402dfca1b 100644
--- a/bsps/sparc/leon3/include/bsp/leon3.h
+++ b/bsps/sparc/leon3/include/bsp/leon3.h
@@ -39,6 +39,7 @@
#include <grlib/apbuart-regs.h>
#include <grlib/gptimer-regs.h>
+#include <bspopts.h>
#include <bsp/irqimpl.h>
@@ -266,7 +267,11 @@ static inline uint32_t leon3_up_counter_frequency( void )
* @brief This pointer provides the debug APBUART register block address.
+#define leon3_debug_uart ((struct apbuart *) LEON3_APBUART_BASE)
+#else
extern apbuart *leon3_debug_uart;
+#endif
diff --git a/bsps/sparc/leon3/include/leon.h b/bsps/sparc/leon3/include/leon.h
index be3819737a..7aa26b43b9 100644
--- a/bsps/sparc/leon3/include/leon.h
+++ b/bsps/sparc/leon3/include/leon.h
@@ -323,6 +323,7 @@ static inline unsigned int leon_r32_no_cache(uintptr_t addr)
extern int syscon_uart_index;
/* Let user override which on-chip APBUART will be debug UART
* 0 = Default APBUART. On MP system CPU0=APBUART0, CPU1=APBUART1...
* 1 = APBUART[0]
@@ -331,6 +332,7 @@ extern int syscon_uart_index;
extern int leon3_debug_uart_index;
+#endif
/* Let user override which on-chip TIMER core will be used for system clock
* timer. This controls which timer core will be accociated with
diff --git a/spec/build/bsps/sparc/leon3/grp.yml b/spec/build/bsps/sparc/leon3/grp.yml
index ab72d911c5..48da9acba8 100644
--- a/spec/build/bsps/sparc/leon3/grp.yml
+++ b/spec/build/bsps/sparc/leon3/grp.yml
@@ -32,6 +32,8 @@ links:
uid: objmpci
- role: build-dependency
uid: objsmp
+- role: build-dependency
+ uid: optapbuartbase
uid: optconirq
diff --git a/spec/build/bsps/sparc/leon3/optapbuartbase.yml b/spec/build/bsps/sparc/leon3/optapbuartbase.yml
new file mode 100644
index 0000000000..2986fc6324
--- /dev/null
+++ b/spec/build/bsps/sparc/leon3/optapbuartbase.yml
@@ -0,0 +1,20 @@
+SPDX-License-Identifier: CC-BY-SA-4.0 OR BSD-2-Clause
+copyrights:
+- Copyright (C) 2021 embedded brains GmbH & Co. KG
+actions:
+- get-integer: null
+- format-and-define: null
+build-type: option
+default:
+- enabled-by: sparc/gr712rc
+ value: 0x80000100
+- enabled-by: sparc/gr740
+ value: 0xff900000
+enabled-by: true
+format: '{:#010x}'
+links: []
+name: LEON3_APBUART_BASE
+description: |
+ This option defines the base address of the debug/console APBUART register
+ block.
+type: build
2.35.3
