[PATCH v2 13/32] bsp/leon3: Use new L2CACHE register block API
Sebastian Huber
Fri Jun 16 06:01:10 UTC 2023
bsps/sparc/leon3/start/cache.c | 38 ++++++++++++++++++++--------------
1 file changed, 23 insertions(+), 15 deletions(-)
diff --git a/bsps/sparc/leon3/start/cache.c b/bsps/sparc/leon3/start/cache.c
index 676f591857..ed6fb5733d 100644
--- a/bsps/sparc/leon3/start/cache.c
+++ b/bsps/sparc/leon3/start/cache.c
@@ -6,9 +6,13 @@
* http://www.rtems.org/license/LICENSE.
-#include <amba.h>
+#include <grlib/l2cache-regs.h>
+#include <grlib/io.h>
#include <bsp/leon3.h>
+#include <grlib/ambapp.h>
#define CPU_CACHE_SUPPORT_PROVIDES_RANGE_FUNCTIONS
#define CPU_CACHE_SUPPORT_PROVIDES_CACHE_SIZE_FUNCTIONS
@@ -19,12 +23,11 @@
#define CPU_DATA_CACHE_ALIGNMENT 64
-static inline volatile struct l2c_regs *get_l2c_regs(void)
+static inline l2cache *get_l2c_regs(void)
- volatile struct l2c_regs *l2c = NULL;
struct ambapp_dev *adev;
- adev = (void *) ambapp_for_each(
+ adev = (struct ambapp_dev *) ambapp_for_each(
ambapp_plb(),
OPTIONS_ALL | OPTIONS_AHB_SLVS,
VENDOR_GAISLER,
@@ -32,27 +35,32 @@ static inline volatile struct l2c_regs *get_l2c_regs(void)
ambapp_find_by_idx,
NULL
- if (adev != NULL) {
- l2c = (volatile struct l2c_regs *) DEV_TO_AHB(adev)->start[1];
+ if (adev == NULL) {
+ return NULL;
- return l2c;
+ return (l2cache *) DEV_TO_AHB(adev)->start[1];
static inline size_t get_l2_size(void)
- size_t size = 0;
- volatile struct l2c_regs *l2c = get_l2c_regs();
+ l2cache *regs;
+ unsigned status;
+ unsigned ways;
+ unsigned set_size;
- if (l2c != NULL) {
- unsigned status = l2c->status;
- unsigned ways = (status & 0x3) + 1;
- unsigned set_size = ((status & 0x7ff) >> 2) * 1024;
+ regs = get_l2c_regs();
- size = ways * set_size;
+ if (regs == NULL) {
+ return 0;
- return size;
+ status = grlib_load_32(®s->l2cs);
+ ways = L2CACHE_L2CS_WAY_GET(status) + 1;
+ set_size = L2CACHE_L2CS_WAY_SIZE_GET(status) * 1024;
+ return ways * set_size;
static inline size_t get_l1_size(uint32_t l1_cfg)
2.35.3
