BSP .inc files and .cfg files
Chris Johns
chrisj at rtems.org
Sun Jun 18 23:21:09 UTC 2023
On 17/6/2023 5:30 am, Joel Sherrill wrote:
> On Fri, Jun 16, 2023 at 3:18 AM Philip Kirkpatrick
> <p.kirkpatrick at reflexaerospace.com <mailto:p.kirkpatrick at reflexaerospace.com>>
> wrote:
> For the RPU patch, I'll add removing this to my next pass at it.
> If there is some transformation on the linked executable needed to download it,
> I hope you document that entire process in the Users Guide. :)
I suspect there is a whole book on how that could be done.
On the Versal it may be as simple as an SMC call but I would need to check the
calls on the Versal [1]. I think it would take a binary image in DDR. I am not
sure what is needed on the ZymqMP?
[1] https://github.com/kiwichris/rtems-xilinx-xrt/tree/main/rtems
