BSP .inc files and .cfg files
Fri Jun 16 19:30:01 UTC 2023
On Fri, Jun 16, 2023 at 3:18 AM Philip Kirkpatrick <
p.kirkpatrick at reflexaerospace.com> wrote:
> For the RPU patch, I'll add removing this to my next pass at it.
If there is some transformation on the linked executable needed to download
it,
I hope you document that entire process in the Users Guide. :)
--joel
> On Fri, Jun 16, 2023 at 6:37 AM Sebastian Huber <
> sebastian.huber at embedded-brains.de> wrote:
>> On 16.06.23 06:35, Chris Johns wrote:
>> > On 16/6/2023 2:33 pm, Sebastian Huber wrote:
>> >> On 16.06.23 03:46, Chris Johns wrote:
>> >>> On 16/6/2023 9:04 am, Joel Sherrill wrote:
>> >>>> On Thu, Jun 15, 2023 at 5:41 PM Chris Johns <chrisj at rtems.org
>> >>>> <mailto:chrisj at rtems.org>> wrote:
>> >>>>       Hi,
>> >>>>       Reviewing the RPU patch I noticed a .inc file being added and
>> I wondered
>> >>>> why so
>> >>>>       I checked the sources and to my surprise found:
>> >>>>       rtems.git $ find bsps -name \*.inc
>> >>>>       bsps/v850/gdbv850sim/config/v850sim.inc
>> >>>>       bsps/m68k/genmcf548x/config/genmcf548x.inc
>> >>>>       bsps/m68k/gen68340/include/m68340.inc
>> >>>>       bsps/m68k/gen68340/include/m68349.inc
>> >>>>       bsps/arm/altera-cyclone-v/config/altcycv.inc
>> >>>>       bsps/arm/raspberrypi/config/raspberrypi.inc
>> >>>>       bsps/arm/lpc32xx/config/lpc32xx.inc
>> >>>>       bsps/arm/beagle/config/beagle.inc
>> >>>>       bsps/arm/tms570/config/tms570ls3137.inc
>> >>>>       bsps/arm/xilinx-zynqmp/config/xilinx_zynqmp.inc
>> >>>>       bsps/arm/xilinx-zynq/config/xilinx_zynq.inc
>> >>>>       bsps/arm/lpc24xx/config/lpc17xx.inc
>> >>>>       bsps/arm/lpc24xx/config/lpc40xx.inc
>> >>>>       bsps/arm/lpc24xx/config/lpc24xx.inc
>> >>>>       bsps/arm/lm3s69xx/config/lm3s69xx.inc
>> >>>>       bsps/powerpc/gen5200/config/gen5200.inc
>> >>>>       bsps/powerpc/tqm8xx/config/tqm8xx.inc
>> >>>>       bsps/powerpc/mpc55xxevb/config/mpc55xx.inc
>> >>>>       bsps/powerpc/qoriq/config/qoriq.inc
>> >>>>       bsps/powerpc/gen83xx/config/gen83xx.inc
>> >>>> These likely can. Thinking back, we have cfg files for every BSP
>> >>>> variant within a family. They often set a variable like CPU and
>> CPU_CFLAGS
>> >>>> and included a shared .inc file. These all appear to be from BSPs
>> which
>> >>>> had variants. I think they are remnants and missed when the .cfg
>> files
>> >>>> were
>> >>>> Would like someone to concur.
>> >>>>       And for .cfg there is:
>> >>>>       rtems.git $ find bsps -name \*.cfg | wc -l
>> >>>>            191
>> >>>> Are these installed and used by the application Makefile system. If
>> so, no.
>> >>> I cannot see any references in spec but Sebastian is the best person
>> to answer
>> >>> this.
>> >> They are definitely not used or installed. I think we still have then
>> since they
>> >> document the post-link actions which are not yet supported by the new
>> build system.
>> > Ah yes, thanks. What if the files are collected and archived?
>> I think we should just remove them. We can use the RTEMS 5 branch to
>> look up the post-link actions if needed.
>> > The RPU BSP is adding a new one. Is this what we want to see happen?
>> No, we don't want to see new ones.
>> embedded brains GmbH
>> Herr Sebastian HUBER
>> Dornierstr. 4
>> 82178 Puchheim
>> Germany
>> email: sebastian.huber at embedded-brains.de
>> phone: +49-89-18 94 741 - 16
>> fax:   +49-89-18 94 741 - 08
>> Registergericht: Amtsgericht München
>> Registernummer: HRB 157899
>> Vertretungsberechtigte Geschäftsführer: Peter Rasmussen, Thomas Dörfler
>> Unsere Datenschutzerklärung finden Sie hier:
>> https://embedded-brains.de/datenschutzerklaerung/
>> devel mailing list
>> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20230616/53eb8bd2/attachment-0001.htm>
