doctest rtems example
Sun Jun 18 23:24:55 UTC 2023
Hi Sam,
Thanks for the post. The website for the code is:
https://github.com/doctest/doctest
I have been using this and I can port tests between Linux and RTEMS. I like it
because it works and it is a single header. There is no need to build and link
libraries.
On 16/6/2023 11:07 pm, Sam Price wrote:
> /* Tell doctest to not use its own main */
> #define DOCTEST_CONFIG_IMPLEMENT
> /* tell doctest to not use sigint that rtems does not have */
> #define DOCTEST_CONFIG_NO_POSIX_SIGNALS
> #include "doctest.h"
> /* Setup command line part */
> const char rtems_test_name[] = "DOCTEST UNIT TESTS";
> static int run_doctest_tests(int argc, char **argv) {
> // Initialize doctest context
> doctest::Context context(argc, argv);
> int test_result = context.run(); // run queries, or run tests unless --no-run
> if(context.shouldExit()) // honor query flags and --exit
> return test_result;
> return 0;
> rtems_shell_cmd_t Shell_DOCTEST_Command = {
> "doctest", /* name */
> "doctest [doctest options]", /* usage */
> "tests", /* topic */
> run_doctest_tests, /* command */
> NULL, /* alias */
> NULL /* next */
> /* Inside of your Init add the following prior to starting shell */
> rtems_task Init(rtems_task_argument ignored)
> rtems_shell_add_cmd_struct(&Shell_DOCTEST_Command);
> /* Note i made this high priority, some of my tests require priority access. */
> /* It may be better to use 100, and use the following in your test
> rtems_task_priority old_priority;
> rtems_task_set_priority(RTEMS_SELF, 0, &old_priority);
> rtems_task_set_priority(RTEMS_SELF, old_priority, 0x0);
> rtems_shell_init("shell0", 20 * 1024, 2, "/dev/console", 0, 1, NULL);
> TEST_CASE("testing the addition function") {
> CHECK((2 + 2) == 4);
> CHECK((2 + 2) == 4.0);
> devel mailing list
> devel at rtems.org
