doctest rtems example
Sam Price
thesamprice at gmail.com
Tue Jun 27 17:10:00 UTC 2023
I was testing the out of box version of gtest.
It does not support parsing arguments more than once.
I think you have to load / unload the library between runs.
I would really prefer to use google test. Its what most of our tests
are already in, and has support for utbot.org
Sam
On Sun, Jun 18, 2023 at 7:25 PM Chris Johns <chrisj at rtems.org> wrote:
> Hi Sam,
> Thanks for the post. The website for the code is:
> https://github.com/doctest/doctest
> I have been using this and I can port tests between Linux and RTEMS. I like it
> because it works and it is a single header. There is no need to build and link
> libraries.
> Chris
> On 16/6/2023 11:07 pm, Sam Price wrote:
> > /* Tell doctest to not use its own main */
> > #define DOCTEST_CONFIG_IMPLEMENT
> > /* tell doctest to not use sigint that rtems does not have */
> > #define DOCTEST_CONFIG_NO_POSIX_SIGNALS
> > #include "doctest.h"
> > /* Setup command line part */
> > const char rtems_test_name[] = "DOCTEST UNIT TESTS";
> > static int run_doctest_tests(int argc, char **argv) {
> > // Initialize doctest context
> > doctest::Context context(argc, argv);
> > int test_result = context.run(); // run queries, or run tests unless --no-run
> > if(context.shouldExit()) // honor query flags and --exit
> > return test_result;
> > return 0;
> > rtems_shell_cmd_t Shell_DOCTEST_Command = {
> > "doctest", /* name */
> > "doctest [doctest options]", /* usage */
> > "tests", /* topic */
> > run_doctest_tests, /* command */
> > NULL, /* alias */
> > NULL /* next */
> > /* Inside of your Init add the following prior to starting shell */
> > rtems_task Init(rtems_task_argument ignored)
> > rtems_shell_add_cmd_struct(&Shell_DOCTEST_Command);
> > /* Note i made this high priority, some of my tests require priority access. */
> > /* It may be better to use 100, and use the following in your test
> > rtems_task_priority old_priority;
> > rtems_task_set_priority(RTEMS_SELF, 0, &old_priority);
> > rtems_task_set_priority(RTEMS_SELF, old_priority, 0x0);
> > rtems_shell_init("shell0", 20 * 1024, 2, "/dev/console", 0, 1, NULL);
> > TEST_CASE("testing the addition function") {
> > CHECK((2 + 2) == 4);
> > CHECK((2 + 2) == 4.0);
> > devel mailing list
> > devel at rtems.org
> devel mailing list
> devel at rtems.org
Sincerely,
Sam Price
