[PATCH rtems-tools] rtemstoolkit: add support for executing pipe command
Muhammad Sulthan Mazaya
msulthanmazaya at gmail.com
Mon Jun 19 22:44:06 UTC 2023
The previous implementation of execute command on rtems-tools config does
not support command line pipe operation. So something like:
%execute %{command} | %{trim_command}
Would not work, since the "| %{trim_command}" part is treated as an
additional command option. This patch is intended to fix that issue.
rtemstoolkit/execute.py | 28 +++++++++++++++++++++++-----
1 file changed, 23 insertions(+), 5 deletions(-)
diff --git a/rtemstoolkit/execute.py b/rtemstoolkit/execute.py
index ed81589..9bb7434 100755
--- a/rtemstoolkit/execute.py
+++ b/rtemstoolkit/execute.py
@@ -389,11 +389,29 @@ class execute(object):
r, e = os.path.splitext(command[0])
if e not in ['.exe', '.com', '.bat']:
command[0] = command[0] + '.exe'
- proc = subprocess.Popen(command, shell = shell,
- cwd = cwd, env = env,
- stdin = stdin, stdout = stdout,
- stderr = stderr,
- close_fds = False)
+ pipe_commands = []
+ current_command = []
+ for cmd in command:
+ if cmd == '|':
+ pipe_commands.append(current_command)
+ else:
+ current_command.append(cmd)
+ proc = None
+ for i, cmd in enumerate(pipe_commands):
+ if i == 0:
+ proc = subprocess.Popen(
+ cmd, shell=shell, cwd=cwd, env=env, stdin=stdin, stdout=subprocess.PIPE)
+ elif i == len(pipe_commands) - 1:
+ cmd, shell=shell, cwd=cwd, env=env, stdin=proc.stdout, stdout=stdout, stderr=stderr, close_fds=False)
+ else:
+ cmd, shell=shell, cwd=cwd, env=env, stdin=proc.stdout, stdout=subprocess.PIPE)
if not capture:
return (0, proc)
if self.output is None:
2.34.1
