[PATCH rtems-tools v2] rtemstoolkit: add support for executing pipe command
Muhammad Sulthan Mazaya
msulthanmazaya at gmail.com
Tue Jun 20 02:32:06 UTC 2023
added unit tests and shorten long lines.
rtemstoolkit/execute.py | 43 ++++++++++++++++++++++++++++++++++++-----
1 file changed, 38 insertions(+), 5 deletions(-)
diff --git a/rtemstoolkit/execute.py b/rtemstoolkit/execute.py
index ed81589..9ec1cd7 100755
--- a/rtemstoolkit/execute.py
+++ b/rtemstoolkit/execute.py
@@ -389,11 +389,38 @@ class execute(object):
r, e = os.path.splitext(command[0])
if e not in ['.exe', '.com', '.bat']:
command[0] = command[0] + '.exe'
- proc = subprocess.Popen(command, shell = shell,
- cwd = cwd, env = env,
- stdin = stdin, stdout = stdout,
- stderr = stderr,
- close_fds = False)
+ pipe_commands = []
+ current_command = []
+ for cmd in command:
+ if cmd == '|':
+ pipe_commands.append(current_command)
+ else:
+ current_command.append(cmd)
+ proc = None
+ for i, cmd in enumerate(pipe_commands):
+ if i == 0:
+ proc = subprocess.Popen(
+ cmd, shell=shell,
+ cwd=cwd, env=env,
+ stdin=stdin, stdout=subprocess.PIPE)
+ elif i == len(pipe_commands) - 1:
+ cmd, shell=shell,
+ cwd=cwd, env=env,
+ stdin=proc.stdout,
+ stdout=stdout, stderr=stderr,
+ close_fds=False)
+ else:
+ cmd, shell=shell,
+ cwd=cwd, env=env,
+ stdout=subprocess.PIPE)
if not capture:
return (0, proc)
if self.output is None:
@@ -583,6 +610,10 @@ if __name__ == "__main__":
proc.stdin.close()
e.capture(proc)
del proc
+ ec, proc = e.open(commands['open'])
+ if ec == 0:
+ e.capture(proc)
+ del proc
def capture_output(text):
print(text, end = '')
@@ -601,6 +632,7 @@ if __name__ == "__main__":
commands['windows']['csubsts'] = [('netstat %0', ['-a']),
('netstat %0 %1', ['-a', '-n'])]
commands['windows']['pipe'] = ('ftp', None, 'help\nquit')
+ commands['windows']['open'] = ["echo", "hello rtems", "|", "findstr", "rtems"]
commands['unix']['shell'] = ['pwd', 'ls -las', './xyz', sh_shell_test]
commands['unix']['spawn'] = ['ls', 'execute.pyc', ['ls', '-i']]
commands['unix']['cmd'] = [('date'), ('date', '-R'), ('date', ['-u', '+%d %D']),
@@ -608,6 +640,7 @@ if __name__ == "__main__":
commands['unix']['csubsts'] = [('date %0 "+%d %D %S"', ['-u']),
('date %0 %1', ['-u', '+%d %D %S'])]
commands['unix']['pipe'] = ('grep', 'hello', 'hello world')
+ commands['unix']['open'] = ["echo", "hello world", "|", "cut", "-d ", "-f2"]
print(arg_list('cmd a1 a2 "a3 is a string" a4'))
print(arg_list('cmd b1 b2 "b3 is a string a4'))
2.34.1
