[PATCH rtems-tools] tester/rt: use shlex.split to split command args
Chris Johns
chrisj at rtems.org
Wed Jun 21 00:37:10 UTC 2023
Pushed
Thanks
On 20/6/2023 8:47 am, Muhammad Sulthan Mazaya wrote:
> The regular split-by-space function used to split command arguments
> creates compatibility issues with many shell command syntaxes. A
> specific example is the handling of string arguments, as shown below:
> %define renode_args -e start_opts -e "s %{bsp_resc_script}"
> Thus, it is changed to use shlex.split instead. It splits
> the command arguments using shell-like syntax. More about shlex
> module here: https://docs.python.org/3/library/shlex.html
> tester/rt/config.py | 3 ++-
> 1 file changed, 2 insertions(+), 1 deletion(-)
> diff --git a/tester/rt/config.py b/tester/rt/config.py
> index 8a433af..bf6fdbf 100644
> --- a/tester/rt/config.py
> +++ b/tester/rt/config.py
> @@ -38,6 +38,7 @@ import datetime
> import os
> import re
> import threading
> +import shlex
> from rtemstoolkit import configuration
> @@ -326,7 +327,7 @@ class file(config.file):
> if len(_data):
> ds = [_data[0]]
> if len(_data) > 1:
> - ds += _data[1].split()
> + ds += shlex.split(_data[1], posix=False)
> ds = self.expand(ds)
> if _directive == '%console':
