[PATCH rtems-tools] rtemstoolkit: Fix shlex.split to use posix mode and add unit test for pipe operation
Chris Johns
chrisj at rtems.org
Wed Jun 21 03:27:21 UTC 2023
On 21/6/2023 11:55 am, Muhammad Sulthan Mazaya wrote:
> Turns out subprocess.Popen operates on posix mode.
Is this true for non-POSIX systems?
Where is this documented?
Also, there is an
> issue with previous implementation of pipe command that is fixed by
> Chris. Now, it can also accepts command in form of a string. The unit
> test for that is added via this patch.
> rtemstoolkit/execute.py | 21 ++++++++++++++-------
> tester/rt/config.py | 2 +-
> 2 files changed, 15 insertions(+), 8 deletions(-)
> diff --git a/rtemstoolkit/execute.py b/rtemstoolkit/execute.py
> index e47aa24..3b7dcb0 100755
> --- a/rtemstoolkit/execute.py
> +++ b/rtemstoolkit/execute.py
> @@ -392,7 +392,7 @@ class execute(object):
> command[0] = command[0] + '.exe'
> # If a string split
> if isinstance(command, str):
> - command = shlex.split(command, posix=False)
> + command = shlex.split(command)
> # See if there is a pipe operator in the command. If present
> # split the commands by the pipe and run them with the pipe.
> # if no pipe it is the normal stdin and stdout
> @@ -623,10 +623,11 @@ if __name__ == "__main__":
> proc.stdin.close()
> e.capture(proc)
> del proc
> - ec, proc = e.open(commands['open'])
> - if ec == 0:
> - e.capture(proc)
> - del proc
> + for c in commands['open']:
> + ec, proc = e.open(c)
> + if ec == 0:
> + e.capture(proc)
> + del proc
> def capture_output(text):
> print(text, end = '')
> @@ -645,7 +646,10 @@ if __name__ == "__main__":
> commands['windows']['csubsts'] = [('netstat %0', ['-a']),
> ('netstat %0 %1', ['-a', '-n'])]
> commands['windows']['pipe'] = ('ftp', None, 'help\nquit')
> - commands['windows']['open'] = ["echo", "hello rtems", "|", "findstr", "rtems"]
> + commands['windows']['open'] = [
> + ["echo", "hello rtems", "|", "findstr", "rtems"],
> + " ".join(["echo", "hello rtems", "|", "findstr", "rtems"])
> commands['unix']['shell'] = ['pwd', 'ls -las', './xyz', sh_shell_test]
> commands['unix']['spawn'] = ['ls', 'execute.pyc', ['ls', '-i']]
> commands['unix']['cmd'] = [('date'), ('date', '-R'), ('date', ['-u', '+%d %D']),
> @@ -653,7 +657,10 @@ if __name__ == "__main__":
> commands['unix']['csubsts'] = [('date %0 "+%d %D %S"', ['-u']),
> ('date %0 %1', ['-u', '+%d %D %S'])]
> commands['unix']['pipe'] = ('grep', 'hello', 'hello world')
> - commands['unix']['open'] = ["echo", "hello world", "|", "cut", "-d ", "-f2"]
> + commands['unix']['open'] = [
> + ["echo", "hello world", "|", "cut", "-d ", "-f2"],
> + " ".join(["echo", "hello world", "|", "cut", "-d\" \"", "-f2"])
> print(arg_list('cmd a1 a2 "a3 is a string" a4'))
> print(arg_list('cmd b1 b2 "b3 is a string a4'))
> diff --git a/tester/rt/config.py b/tester/rt/config.py
> index c0c31de..3b12c6c 100644
> --- a/tester/rt/config.py
> +++ b/tester/rt/config.py
> @@ -327,7 +327,7 @@ class file(config.file):
> if len(_data):
> ds = [_data[0]]
> if len(_data) > 1:
> - ds += shlex.split(_data[1], posix=False)
> + ds += shlex.split(_data[1])
> ds = self.expand(ds)
> if _directive == '%console':
