[PATCH rtems-tools] rtemstoolkit: Fix shlex.split to use posix mode and add unit test for pipe operation
Muhammad Sulthan Mazaya
msulthanmazaya at gmail.com
Wed Jun 21 04:22:23 UTC 2023
> On 21/6/2023 11:55 am, Muhammad Sulthan Mazaya wrote:
> > Turns out subprocess.Popen operates on posix mode.
> Is this true for non-POSIX systems?
> Where is this documented?
It's not, turns out it is also dependent on the system too. It is
documented here
https://docs.python.org/3/library/subprocess.html#subprocess.Popen. Should
I add a check like this instead?
rtemstoolkit/execute.py | 21 ++++++++++++++-------
tester/rt/config.py | 2 +-
2 files changed, 15 insertions(+), 8 deletions(-)
diff --git a/rtemstoolkit/execute.py b/rtemstoolkit/execute.py
index e47aa24..5f0d94b 100755
--- a/rtemstoolkit/execute.py
+++ b/rtemstoolkit/execute.py
@@ -392,7 +392,7 @@ class execute(object):
command[0] = command[0] + '.exe'
# If a string split
if isinstance(command, str):
- command = shlex.split(command, posix=False)
+ command = shlex.split(command, posix=(os.name == 'posix'))
# See if there is a pipe operator in the command. If present
# split the commands by the pipe and run them with the pipe.
# if no pipe it is the normal stdin and stdout
@@ -623,10 +623,11 @@ if __name__ == "__main__":
proc.stdin.close()
e.capture(proc)
del proc
- ec, proc = e.open(commands['open'])
- if ec == 0:
- e.capture(proc)
- del proc
+ for c in commands['open']:
+ ec, proc = e.open(c)
+ if ec == 0:
+ e.capture(proc)
+ del proc
def capture_output(text):
print(text, end = '')
@@ -645,7 +646,10 @@ if __name__ == "__main__":
commands['windows']['csubsts'] = [('netstat %0', ['-a']),
('netstat %0 %1', ['-a', '-n'])]
commands['windows']['pipe'] = ('ftp', None, 'help\nquit')
- commands['windows']['open'] = ["echo", "hello rtems", "|", "findstr",
"rtems"]
+ commands['windows']['open'] = [
+ ["echo", "hello rtems", "|", "findstr", "rtems"],
+ " ".join(["echo", "hello rtems", "|", "findstr", "rtems"])
commands['unix']['shell'] = ['pwd', 'ls -las', './xyz', sh_shell_test]
commands['unix']['spawn'] = ['ls', 'execute.pyc', ['ls', '-i']]
commands['unix']['cmd'] = [('date'), ('date', '-R'), ('date', ['-u',
'+%d %D']),
@@ -653,7 +657,10 @@ if __name__ == "__main__":
commands['unix']['csubsts'] = [('date %0 "+%d %D %S"', ['-u']),
('date %0 %1', ['-u', '+%d %D %S'])]
commands['unix']['pipe'] = ('grep', 'hello', 'hello world')
- commands['unix']['open'] = ["echo", "hello world", "|", "cut", "-d ",
"-f2"]
+ commands['unix']['open'] = [
+ ["echo", "hello world", "|", "cut", "-d ", "-f2"],
+ " ".join(["echo", "hello world", "|", "cut", "-d\" \"", "-f2"])
print(arg_list('cmd a1 a2 "a3 is a string" a4'))
print(arg_list('cmd b1 b2 "b3 is a string a4'))
diff --git a/tester/rt/config.py b/tester/rt/config.py
index c0c31de..ceb044e 100644
--- a/tester/rt/config.py
+++ b/tester/rt/config.py
@@ -327,7 +327,7 @@ class file(config.file):
if len(_data):
ds = [_data[0]]
if len(_data) > 1:
- ds += shlex.split(_data[1], posix=False)
+ ds += shlex.split(_data[1], posix=(os.name == 'posix'))
ds = self.expand(ds)
if _directive == '%console':
2.34.1
> Chris
> Also, there is an
> > issue with previous implementation of pipe command that is fixed by
> > Chris. Now, it can also accepts command in form of a string. The unit
> > test for that is added via this patch.
> > index e47aa24..3b7dcb0 100755
> > # If a string split
> > + command = shlex.split(command)
> > proc.stdin.close()
> > e.capture(proc)
> > del proc
> > - if ec == 0:
> > - e.capture(proc)
> > - del proc
> > + if ec == 0:
> > + e.capture(proc)
> > + del proc
> "findstr", "rtems"]
> sh_shell_test]
> ['-u', '+%d %D']),
> ", "-f2"]
> "-f2"])
> > index c0c31de..3b12c6c 100644
> > if len(_data):
> > ds = [_data[0]]
> > if len(_data) > 1:
> > + ds += shlex.split(_data[1])
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20230621/ff2895d6/attachment-0001.htm>
