[PATCH rtems-tools] tester/rtems: add renode implementation
Muhammad Sulthan Mazaya
msulthanmazaya at gmail.com
Mon Jun 26 22:37:11 UTC 2023
Hi Chris,
Yes they are the same. I thought there was an email error, so I re-send it
twice.
On Tue, 27 Jun 2023, 07:46 Chris Johns, <chrisj at rtems.org> wrote:
> Hi Muhammad,
> The patch looks good, thanks.
> Are the 3 posted patches the same version?
> Chris
> On 26/6/2023 2:17 pm, Muhammad Sulthan Mazaya wrote:
> > Patch for the implementation of renode on rtems-test. Currently, renode
> > installation has not been implemented in rsb. Thus, for testing, you can
> > install renode by referring to the documentation link below.
> > Downloads for debian, fedora, arch, macOS, and windows:
> > https://renode.io/#downloads
> > Alternatively, you can access Renode's GitHub releases:
> > https://github.com/renode/renode/releases/tag/v1.13.3
> > You can also build it from source:
> https://renode.readthedocs.io/en/latest/advanced/building_from_sources.html#building-from-source
> > This patch consists of changes to test kendrytek210 using renode. To
> > test it, you can build the kendrytek210 test suite as instructed in the
> > rtems-docs (Alan's patch here:
> https://lists.rtems.org/pipermail/devel/2023-April/074838.html).
> > Then, use the following command to run the test suite.
> > rtems-test --rtems-bsp=kendrytek210-renode [test-suite-path]
> > .../testing/bsps/kendrytek210-renode.ini | 38 +++++++++++
> > tester/rtems/testing/renode.cfg | 64 +++++++++++++++++++
> > .../testing/renode_scripts/kendrytek210.resc | 53 +++++++++++++++
> > 3 files changed, 155 insertions(+)
> > create mode 100644 tester/rtems/testing/bsps/kendrytek210-renode.ini
> > create mode 100644 tester/rtems/testing/renode.cfg
> > create mode 100644 tester/rtems/testing/renode_scripts/kendrytek210.resc
> > diff --git a/tester/rtems/testing/bsps/kendrytek210-renode.ini
> b/tester/rtems/testing/bsps/kendrytek210-renode.ini
> > new file mode 100644
> > index 0000000..95850c5
> > --- /dev/null
> > +++ b/tester/rtems/testing/bsps/kendrytek210-renode.ini
> > @@ -0,0 +1,38 @@
> > +# RTEMS Tools Project (http://www.rtems.org/)
> > +# Copyright 2010-2014 Chris Johns (chrisj at rtems.org)
> > +# All rights reserved.
> > +# This file is part of the RTEMS Tools package in 'rtems-tools'.
> > +# Redistribution and use in source and binary forms, with or without
> > +# modification, are permitted provided that the following conditions
> are met:
> > +# 1. Redistributions of source code must retain the above copyright
> notice,
> > +# this list of conditions and the following disclaimer.
> > +# 2. Redistributions in binary form must reproduce the above copyright
> notice,
> > +# this list of conditions and the following disclaimer in the
> documentation
> > +# and/or other materials provided with the distribution.
> > +# THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS
> "AS IS"
> > +# AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO,
> THE
> > +# IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR
> PURPOSE
> > +# ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT HOLDER OR
> CONTRIBUTORS BE
> > +# LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
> > +# CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
> > +# SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR
> BUSINESS
> > +# INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER
> IN
> > +# CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR
> OTHERWISE)
> > +# ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED
> OF THE
> > +# POSSIBILITY OF SUCH DAMAGE.
> > +# The Kendrytek210 Renode BSP
> > +[kendrytek210-renode]
> > +bsp = kendrytek210-renode
> > +arch = riscv
> > +tester = %{_rtscripts}/renode.cfg
> > +bsp_resc_script = %{_rtscripts}/renode_scripts/kendrytek210.resc
> > diff --git a/tester/rtems/testing/renode.cfg
> b/tester/rtems/testing/renode.cfg
> > index 0000000..49e84a5
> > --- /dev/null
> > +++ b/tester/rtems/testing/renode.cfg
> > @@ -0,0 +1,64 @@
> are met:
> notice,
> notice,
> documentation
> "AS IS"
> THE
> PURPOSE
> CONTRIBUTORS BE
> BUSINESS
> IN
> OTHERWISE)
> OF THE
> > +# Renode
> > +# Use a renode command to run the executable in the renode simulator.
> > +%include %{_configdir}/base.cfg
> > +%include %{_configdir}/checks.cfg
> > +# Console.
> > +%define console_telnet
> > +%include %{_configdir}/console.cfg
> > +# RTEMS version
> > +%include %{_rtdir}/rtems/version.cfg
> > +# Renode executable
> > +%define renode_cmd renode --hide-monitor
> > +%define binary_opts -e $bin?=@%{test_executable}
> > +%define start_opts -e "s @%{bsp_resc_script}"
> > +%define trim_command sed 's/.*\[output\] //'
> > +# Executable
> > +%execute %{renode_cmd} %{binary_opts} %{start_opts} | %{trim_command}
> > diff --git a/tester/rtems/testing/renode_scripts/kendrytek210.resc
> b/tester/rtems/testing/renode_scripts/kendrytek210.resc
> > index 0000000..fe13aa8
> > --- /dev/null
> > +++ b/tester/rtems/testing/renode_scripts/kendrytek210.resc
> > @@ -0,0 +1,53 @@
> > +using sysbus
> > +using monitor
> > +mach create "K210"
> > +machine LoadPlatformDescription @platforms/cpus/kendryte_k210.repl
> > +path add @/
> > +showAnalyzer "uartAnalyzer" uart
> Antmicro.Renode.Analyzers.LoggingUartAnalyzer
> > +uartAnalyzer TimestampFormat None
> > +set report_repeating_line """
> > +from Antmicro.Renode.Logging import ConsoleBackend
> > +ConsoleBackend.Instance.ReportRepeatingLines = True
> > +set add_hook """
> > +def match(line):
> > + ok_to_kill_lines = [
> > + '*** TEST STATE: USER_INPUT',
> > + '*** TEST STATE: BENCHMARK',
> > + '*** END OF TEST ',
> > + '*** FATAL ***'
> > + return any(l in line for l in ok_to_kill_lines)
> > +def hook(line):
> > + monitor.Parse("q")
> +Antmicro.Renode.Hooks.UartHooksExtensions.AddLineHook(monitor.Machine["sysbus.uart"],
> match, hook)
> > +python $add_hook
> > +python $report_repeating_line
> > +sysbus Tag <0x50440000 0x10000> "SYSCTL"
> > +sysbus Tag <0x50440018 0x4> "pll_lock" 0xFFFFFFFF
> > +sysbus Tag <0x5044000C 0x4> "pll1"
> > +sysbus Tag <0x50440008 0x4> "pll0"
> > +sysbus Tag <0x50440020 0x4> "clk_sel0"
> > +sysbus Tag <0x50440028 0x4> "clk_en_cent"
> > +sysbus Tag <0x5044002c 0x4> "clk_en_peri"
> > +# enable uart tx
> > +uart WriteDoubleWord 0x8 0x1
> > +macro reset
> > + sysbus LoadELF $bin
> > +runMacro $reset
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20230627/2820384a/attachment-0001.htm>
