[PATCH rtems-tools] tester/rtems: add renode implementation
Tue Jun 27 14:25:15 UTC 2023
I'm OK with this patch.
Is it assuming that you installed renode on your own -- not using the RSB?
--joel
On Mon, Jun 26, 2023 at 5:37 PM Muhammad Sulthan Mazaya <
msulthanmazaya at gmail.com> wrote:
> Hi Chris,
> Yes they are the same. I thought there was an email error, so I re-send it
> twice.
> On Tue, 27 Jun 2023, 07:46 Chris Johns, <chrisj at rtems.org> wrote:
>> Hi Muhammad,
>> The patch looks good, thanks.
>> Are the 3 posted patches the same version?
>> Chris
>> On 26/6/2023 2:17 pm, Muhammad Sulthan Mazaya wrote:
>> > Patch for the implementation of renode on rtems-test. Currently, renode
>> > installation has not been implemented in rsb. Thus, for testing, you can
>> > install renode by referring to the documentation link below.
>> > Downloads for debian, fedora, arch, macOS, and windows:
>> > https://renode.io/#downloads
>> > Alternatively, you can access Renode's GitHub releases:
>> > https://github.com/renode/renode/releases/tag/v1.13.3
>> > You can also build it from source:
>> https://renode.readthedocs.io/en/latest/advanced/building_from_sources.html#building-from-source
>> > This patch consists of changes to test kendrytek210 using renode. To
>> > test it, you can build the kendrytek210 test suite as instructed in the
>> > rtems-docs (Alan's patch here:
>> https://lists.rtems.org/pipermail/devel/2023-April/074838.html).
>> > Then, use the following command to run the test suite.
>> > rtems-test --rtems-bsp=kendrytek210-renode [test-suite-path]
>> >  .../testing/bsps/kendrytek210-renode.ini      | 38 +++++++++++
>> >  tester/rtems/testing/renode.cfg               | 64 +++++++++++++++++++
>> >  .../testing/renode_scripts/kendrytek210.resc  | 53 +++++++++++++++
>> >  3 files changed, 155 insertions(+)
>> >  create mode 100644 tester/rtems/testing/bsps/kendrytek210-renode.ini
>> >  create mode 100644 tester/rtems/testing/renode.cfg
>> >  create mode 100644
>> tester/rtems/testing/renode_scripts/kendrytek210.resc
>> > diff --git a/tester/rtems/testing/bsps/kendrytek210-renode.ini
>> b/tester/rtems/testing/bsps/kendrytek210-renode.ini
>> > new file mode 100644
>> > index 0000000..95850c5
>> > --- /dev/null
>> > +++ b/tester/rtems/testing/bsps/kendrytek210-renode.ini
>> > @@ -0,0 +1,38 @@
>> > +# RTEMS Tools Project (http://www.rtems.org/)
>> > +# Copyright 2010-2014 Chris Johns (chrisj at rtems.org)
>> > +# All rights reserved.
>> > +# This file is part of the RTEMS Tools package in 'rtems-tools'.
>> > +# Redistribution and use in source and binary forms, with or without
>> > +# modification, are permitted provided that the following conditions
>> are met:
>> > +# 1. Redistributions of source code must retain the above copyright
>> notice,
>> > +# this list of conditions and the following disclaimer.
>> > +# 2. Redistributions in binary form must reproduce the above copyright
>> notice,
>> > +# this list of conditions and the following disclaimer in the
>> documentation
>> > +# and/or other materials provided with the distribution.
>> > +# THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS
>> "AS IS"
>> > +# AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED
>> TO, THE
>> > +# IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR
>> PURPOSE
>> > +# ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT HOLDER OR
>> CONTRIBUTORS BE
>> > +# LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
>> > +# CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
>> > +# SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR
>> BUSINESS
>> > +# INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER
>> IN
>> > +# CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR
>> OTHERWISE)
>> > +# ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED
>> OF THE
>> > +# POSSIBILITY OF SUCH DAMAGE.
>> > +# The Kendrytek210 Renode BSP
>> > +[kendrytek210-renode]
>> > +bsp             = kendrytek210-renode
>> > +arch            = riscv
>> > +tester          = %{_rtscripts}/renode.cfg
>> > +bsp_resc_script = %{_rtscripts}/renode_scripts/kendrytek210.resc
>> > diff --git a/tester/rtems/testing/renode.cfg
>> b/tester/rtems/testing/renode.cfg
>> > index 0000000..49e84a5
>> > --- /dev/null
>> > +++ b/tester/rtems/testing/renode.cfg
>> > @@ -0,0 +1,64 @@
>> are met:
>> notice,
>> notice,
>> documentation
>> "AS IS"
>> TO, THE
>> PURPOSE
>> CONTRIBUTORS BE
>> BUSINESS
>> IN
>> OTHERWISE)
>> OF THE
>> > +# Renode
>> > +# Use a renode command to run the executable in the renode simulator.
>> > +%include %{_configdir}/base.cfg
>> > +%include %{_configdir}/checks.cfg
>> > +# Console.
>> > +%define console_telnet
>> > +%include %{_configdir}/console.cfg
>> > +# RTEMS version
>> > +%include %{_rtdir}/rtems/version.cfg
>> > +# Renode executable
>> > +%define renode_cmd renode --hide-monitor
>> > +%define binary_opts -e $bin?=@%{test_executable}
>> > +%define start_opts -e "s @%{bsp_resc_script}"
>> > +%define trim_command sed 's/.*\[output\] //'
>> > +# Executable
>> > +%execute %{renode_cmd} %{binary_opts} %{start_opts} | %{trim_command}
>> > diff --git a/tester/rtems/testing/renode_scripts/kendrytek210.resc
>> b/tester/rtems/testing/renode_scripts/kendrytek210.resc
>> > index 0000000..fe13aa8
>> > --- /dev/null
>> > +++ b/tester/rtems/testing/renode_scripts/kendrytek210.resc
>> > @@ -0,0 +1,53 @@
>> > +using sysbus
>> > +using monitor
>> > +mach create "K210"
>> > +machine LoadPlatformDescription @platforms/cpus/kendryte_k210.repl
>> > +path add @/
>> > +showAnalyzer "uartAnalyzer" uart
>> Antmicro.Renode.Analyzers.LoggingUartAnalyzer
>> > +uartAnalyzer TimestampFormat None
>> > +set report_repeating_line """
>> > +from Antmicro.Renode.Logging import ConsoleBackend
>> > +ConsoleBackend.Instance.ReportRepeatingLines = True
>> > +set add_hook """
>> > +def match(line):
>> > +    ok_to_kill_lines = [
>> > +        '*** TEST STATE: USER_INPUT',
>> > +        '*** TEST STATE: BENCHMARK',
>> > +        '*** END OF TEST ',
>> > +        '*** FATAL ***'
>> > +    return any(l in line for l in ok_to_kill_lines)
>> > +def hook(line):
>> > +    monitor.Parse("q")
>> +Antmicro.Renode.Hooks.UartHooksExtensions.AddLineHook(monitor.Machine["sysbus.uart"],
>> match, hook)
>> > +python $add_hook
>> > +python $report_repeating_line
>> > +sysbus Tag <0x50440000 0x10000> "SYSCTL"
>> > +sysbus Tag <0x50440018 0x4> "pll_lock" 0xFFFFFFFF
>> > +sysbus Tag <0x5044000C 0x4> "pll1"
>> > +sysbus Tag <0x50440008 0x4> "pll0"
>> > +sysbus Tag <0x50440020 0x4> "clk_sel0"
>> > +sysbus Tag <0x50440028 0x4> "clk_en_cent"
>> > +sysbus Tag <0x5044002c 0x4> "clk_en_peri"
>> > +# enable uart tx
>> > +uart WriteDoubleWord 0x8 0x1
>> > +macro reset
>> > +    sysbus LoadELF $bin
>> > +runMacro $reset
>> devel mailing list
>> devel at rtems.org
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20230627/0fe36495/attachment.htm>
