[PATCH rtems-libbsd] freebsd/if_cgem: Remove QEMU workaround
Kinsey Moore
kinsey.moore at oarcorp.com
Tue Jun 27 15:28:16 UTC 2023
This removes the workaround applied on the fly for QEMU that disables
priority queueing. The priority queue interrupt was not previously
hooked up properly in QEMU and RSB now has the patches to allow it to
work.
freebsd/sys/dev/cadence/if_cgem.c | 26 +++++++-------------------
1 file changed, 7 insertions(+), 19 deletions(-)
diff --git a/freebsd/sys/dev/cadence/if_cgem.c b/freebsd/sys/dev/cadence/if_cgem.c
index 689c3611..c1c88e77 100644
--- a/freebsd/sys/dev/cadence/if_cgem.c
+++ b/freebsd/sys/dev/cadence/if_cgem.c
@@ -133,7 +133,6 @@ struct cgem_softc {
uint32_t net_ctl_shadow;
#ifdef __rtems__
uint32_t net_cfg_shadow;
- int neednullqs;
int phy_contype;
#endif /* __rtems__ */
int ref_clk_num;
@@ -458,9 +457,8 @@ cgem_setup_descs(struct cgem_softc *sc)
int desc_rings_size = CGEM_NUM_RX_DESCS * sizeof(struct cgem_rx_desc) +
CGEM_NUM_TX_DESCS * sizeof(struct cgem_tx_desc);
- if (sc->neednullqs)
- desc_rings_size += sizeof(struct cgem_rx_desc) +
- sizeof(struct cgem_tx_desc);
+ desc_rings_size += sizeof(struct cgem_rx_desc) +
+ sizeof(struct cgem_tx_desc);
sc->txring = NULL;
sc->rxring = NULL;
@@ -609,13 +607,11 @@ cgem_setup_descs(struct cgem_softc *sc)
sc->txring_queued = 0;
#ifdef __rtems__
- if (sc->neednullqs) {
- sc->null_qs = (void *)(sc->txring + CGEM_NUM_TX_DESCS);
- sc->null_qs_physaddr = sc->txring_physaddr +
- CGEM_NUM_TX_DESCS * sizeof(struct cgem_tx_desc);
+ sc->null_qs = (void *)(sc->txring + CGEM_NUM_TX_DESCS);
+ sc->null_qs_physaddr = sc->txring_physaddr +
+ CGEM_NUM_TX_DESCS * sizeof(struct cgem_tx_desc);
- cgem_null_qs(sc);
+ cgem_null_qs(sc);
return (0);
@@ -2074,15 +2070,7 @@ cgem_attach(device_t dev)
sc->if_old_flags = if_getflags(ifp);
sc->rxbufs = DEFAULT_NUM_RX_BUFS;
-#if defined(CGEM64) && defined(__rtems__)
- uint32_t design_cfg6 = RD4(sc, CGEM_DESIGN_CFG6);
- * QEMU does not have PBUF_CUTTHRU defined and is broken when trying
- * to use nullqs
- if ((design_cfg6 & CGEM_DESIGN_CFG6_PBUF_CUTTHRU))
- sc->neednullqs = 1;
-#else
+#if !defined(CGEM64) && defined(__rtems__)
sc->rxhangwar = 1;
#endif
2.30.2
