[RSB 2/4] 6: Update GCC 10 and 12
Wed Jun 28 05:33:11 UTC 2023
On 28.06.23 04:37, Chris Johns wrote:
> Can you please provide something other than update in the commit message?
> If it is to pick up patches on these gcc release branches then please say so.
This update has no particular reason. I just had a bit of time to run my
update script. Ideally there would be an automatic update process in
place. If you don't want to follow the upstream release branches, then
please say so. However, this work helps to identify RTEMS related issues
in the upstream development. Working tools for RTEMS need maintenance.
It is not that release versions of GCC magically work on RTEMS.
> Are these versions of the compiler tracking tarfile packages?
No, the configurations track the release branches.
embedded brains GmbH
Herr Sebastian HUBER
Dornierstr. 4
82178 Puchheim
Germany
phone: +49-89-18 94 741 - 16
fax:   +49-89-18 94 741 - 08
Registernummer: HRB 157899
