[RSB 2/4] 6: Update GCC 10 and 12
Thu Jun 29 00:20:17 UTC 2023
On 28/6/2023 3:33 pm, Sebastian Huber wrote:
> On 28.06.23 04:37, Chris Johns wrote:
>> Can you please provide something other than update in the commit message?
>> If it is to pick up patches on these gcc release branches then please say so.
> This update has no particular reason. I just had a bit of time to run my update
> script. Ideally there would be an automatic update process in place. If you
> don't want to follow the upstream release branches, then please say so. However,
> this work helps to identify RTEMS related issues in the upstream development.
> Working tools for RTEMS need maintenance. It is not that release versions of GCC
> magically work on RTEMS.
This sounds great. Would it be possible to add a simple comment in the commit
message this is a housekeeping update to the latest? It makes it easier
reviewing the commit log to understand changes of interest verses such as things
we need or make in newlib verses housekeeping.
>> Are these versions of the compiler tracking tarfile packages?
> No, the configurations track the release branches.
For newlib this makes sense during development and releases because of newlib's
long release period. It also works for binutils, gcc and gdb when we are in
development however I am not sure it does with releases. Should we look to
tarfiles for releases for the binutils, gcc and gdb tools?
