[PATCH rtems] Remove unused _IO_Relax
Wed Jun 28 16:17:20 UTC 2023
On Wed, Jun 28, 2023 at 11:07 AM Sebastian Huber <
> On 28.06.23 18:05, Joel Sherrill wrote:
> > The only use was in a test.
> This function is used by this patch set:
> https://lists.rtems.org/pipermail/devel/2023-June/075497.html
(1) Not in the source repository
(2) Even if it was, this code does not belong in the score. It looks more
like BSP support code that some drivers need.
If you want it to stay, rename and move it. I am starting a pass to clean
some things in the score that are not really core to the OS proper and are
in the wrong place.
--joel
> embedded brains GmbH
> Herr Sebastian HUBER
> Dornierstr. 4
> 82178 Puchheim
> Germany
> email: sebastian.huber at embedded-brains.de
> phone: +49-89-18 94 741 - 16
> fax:   +49-89-18 94 741 - 08
> Registergericht: Amtsgericht München
> Registernummer: HRB 157899
> Vertretungsberechtigte Geschäftsführer: Peter Rasmussen, Thomas Dörfler
> Unsere Datenschutzerklärung finden Sie hier:
> https://embedded-brains.de/datenschutzerklaerung/
URL: <http://lists.rtems.org/pipermail/devel/attachments/20230628/1d228424/attachment.htm>
