[PATCH rtems] Remove unused _IO_Relax
Sebastian Huber
Wed Jun 28 16:29:29 UTC 2023
On 28.06.23 18:17, Joel Sherrill wrote:
> On Wed, Jun 28, 2023 at 11:07 AM Sebastian Huber
> <sebastian.huber at embedded-brains.de
> <mailto:sebastian.huber at embedded-brains.de>> wrote:
> On 28.06.23 18:05, Joel Sherrill wrote:
> > The only use was in a test.
> This function is used by this patch set:
> https://lists.rtems.org/pipermail/devel/2023-June/075497.html
> <https://lists.rtems.org/pipermail/devel/2023-June/075497.html>
> (1) Not in the source repository
I didn't expect that the BSP update integration takes about two years.
> (2) Even if it was, this code does not belong in the score. It looks
> more like BSP support code that some drivers need.
Where would you place this code?
embedded brains GmbH
Herr Sebastian HUBER
Dornierstr. 4
82178 Puchheim
Germany
phone: +49-89-18 94 741 - 16
fax: +49-89-18 94 741 - 08
Registernummer: HRB 157899
