[PATCH rtems-docs v2] c-user: Update references to rtems_task_wake_after
Kinsey Moore
kinsey.moore at oarcorp.com
Wed Jun 28 18:27:32 UTC 2023
rtems_task_wake_after takes a parameter in terms of a count of clock
ticks and not a measure in a subunit of seconds. This updates
documentation to reflect that.
Updates #4772
c-user/scheduling-concepts/background.rst | 8 ++++----
c-user/task/operations.rst | 6 +++---
2 files changed, 7 insertions(+), 7 deletions(-)
diff --git a/c-user/scheduling-concepts/background.rst b/c-user/scheduling-concepts/background.rst
index 1fe7089..38b77ee 100644
--- a/c-user/scheduling-concepts/background.rst
+++ b/c-user/scheduling-concepts/background.rst
@@ -160,7 +160,7 @@ Manual Round-Robin
The final mechanism for altering the RTEMS scheduling algorithm is called
manual round-robin. Manual round-robin is invoked by using
-the ``rtems_task_wake_after`` directive with a time interval of
+the ``rtems_task_wake_after`` directive with a ``ticks`` parameter of
``RTEMS_YIELD_PROCESSOR``. This allows a task to give up the processor and be
immediately returned to the ready chain at the end of its priority group. If
no other tasks of the same priority are ready to run, then the task does not
@@ -243,7 +243,7 @@ of the following conditions:
option and the requested semaphore is unavailable.
- The running task issues a ``rtems_task_wake_after`` directive which blocks
- the task for the given time interval. If the time interval specified is
+ the task for the given count of ticks. If the count of ticks specified is
zero, the task yields the processor and remains in the ready state.
- The running task issues a ``rtems_task_wake_when`` directive which blocks the
@@ -280,8 +280,8 @@ conditions:
- A running task issues a ``rtems_semaphore_release`` directive which releases
the semaphore on which the blocked task is waiting.
-- A timeout interval expires for a task which was blocked by a call to the
- ``rtems_task_wake_after`` directive.
+- The requested count of ticks has elapsed for a task which was blocked by a
+ call to the ``rtems_task_wake_after`` directive.
- A timeout period expires for a task which blocked by a call to the
``rtems_task_wake_when`` directive.
diff --git a/c-user/task/operations.rst b/c-user/task/operations.rst
index 6308d7b..438eea5 100644
--- a/c-user/task/operations.rst
+++ b/c-user/task/operations.rst
@@ -75,9 +75,9 @@ Delaying the Currently Executing Task
The ``rtems_task_wake_after`` directive creates a sleep timer which allows a
-task to go to sleep for a specified interval. The task is blocked until the
-delay interval has elapsed, at which time the task is unblocked. A task
-calling the ``rtems_task_wake_after`` directive with a delay interval of
+task to go to sleep for a specified count of clock ticks. The task is blocked
+until the count of clock ticks has elapsed, at which time the task is unblocked.
+A task calling the ``rtems_task_wake_after`` directive with a delay of
``RTEMS_YIELD_PROCESSOR`` ticks will yield the processor to any other ready
task of equal or greater priority and remain ready to execute.
2.30.2
