[PATCH rtems-central] spec/wake-after: Update references to intervals
Kinsey Moore
kinsey.moore at oarcorp.com
Wed Jun 28 18:31:20 UTC 2023
Thanks, v2 coming shortly.
Kinsey
On Wed, Jun 28, 2023 at 1:28 PM Sebastian Huber <
> On 28.06.23 20:22, Kinsey Moore wrote:
> > rtems_task_wake_after takes a parameter in terms of a count of clock
> > ticks and not a measure in a subunit of seconds. This updates
> > documentation to reflect that and recommends clock_nanosleep() for
> > applications requiring sleep for a time-based duration instead of a
> > count of clock ticks.
> > Updates #4772
> > spec/rtems/task/if/wake-after.yml | 26 +++++++++++++++-----------
> > 1 file changed, 15 insertions(+), 11 deletions(-)
> > diff --git a/spec/rtems/task/if/wake-after.yml
> b/spec/rtems/task/if/wake-after.yml
> > index b3805251..a5791f14 100644
> > --- a/spec/rtems/task/if/wake-after.yml
> > +++ b/spec/rtems/task/if/wake-after.yml
> > @@ -1,7 +1,7 @@
> > SPDX-License-Identifier: CC-BY-SA-4.0 OR BSD-2-Clause
> > brief: |
> > - Wakes up after an interval in ${/glossary/clock-tick:/plural} or
> yields the
> > - processor.
> > + Wakes up after a count of ${/glossary/clock-tick:/plural} have
> occurred or
> > + yields the processor.
> > copyrights:
> > - Copyright (C) 2021 embedded brains GmbH (
> http://www.embedded-brains.de)
> > - Copyright (C) 1988, 2017 On-Line Applications Research Corporation
> (OAR)
> Maybe update to 2023.
> > @@ -15,15 +15,15 @@ definition:
> > variants: []
> > description: |
> > This directive blocks the calling task for the specified
> ${.:/params[0]/name}
> > - of clock ticks if the value is not equal to
> ${yield-processor:/name}. When
> > - the requested interval has elapsed, the task is made ready. The
> clock tick
> > - directives automatically updates the delay period. The calling task
> may give
> > - up the processor and remain in the ready state by specifying a value
> of
> > - ${yield-processor:/name} in ${.:/params[0]/name}.
> > + count of clock ticks if the value is not equal to
> > + When the requested count of ticks have occurred, the task is made
> ready. The
> > + clock tick directives automatically update the delay period. The
> calling task
> > + may give up the processor and remain in the ready state by specifying
> a value
> > + of ${yield-processor:/name} in ${.:/params[0]/name}.
> > enabled-by: true
> > index-entries:
> > -- delay a task for an interval
> > -- wake up after an interval
> > +- delay a task for a count of clock ticks
> > +- wake up after a count of clock ticks
> > interface-type: function
> > links:
> > - role: interface-placement
> > @@ -40,10 +40,14 @@ name: rtems_task_wake_after
> > notes: |
> > Setting the system date and time with the ${../../clock/if/set:/name}
> > directive and similar directives which set
> ${/glossary/clock-realtime:/term}
> > - have no effect on a ${wake-after:/name} blocked task.
> > + have no effect on a ${wake-after:/name} blocked task. The delay
> until first
> > + clock tick will never be a whole clock tick interval since this
> directive will
> > + never excute exactly on a clock tick. Applications requiring use of
> a clock
> > + (CLOCK_REALTIME or CLOCK_MONOTONIC) instead of clock ticks should
> make use of
> (${/glossary/clock-realtime:/term} or
> ${/glossary/clock-monotonic:/term}) instead...
> > + ${/c/if/clock-nanosleep:/name}.
> > params:
> > - description: |
> > - is the interval in ${/glossary/clock-tick:/plural} to delay the
> task or
> > + is the count of ${/glossary/clock-tick:/plural} to delay the task or
> > ${yield-processor:/name} to yield the processor.
> > dir: null
> Thanks, it is now clear to me.
> Herr Sebastian HUBER
> Dornierstr. 4
> 82178 Puchheim
> Germany
> email: sebastian.huber at embedded-brains.de
> phone: +49-89-18 94 741 - 16
> fax: +49-89-18 94 741 - 08
> Registergericht: Amtsgericht München
> Registernummer: HRB 157899
> Vertretungsberechtigte Geschäftsführer: Peter Rasmussen, Thomas Dörfler
> Unsere Datenschutzerklärung finden Sie hier:
> https://embedded-brains.de/datenschutzerklaerung/
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20230628/f5b05c65/attachment-0001.htm>
