[PATCH rtems] Remove unused _IO_Relax
Wed Jun 28 18:37:45 UTC 2023
On Wed, Jun 28, 2023 at 12:17 PM Sebastian Huber <
> On 28.06.23 19:02, Joel Sherrill wrote:
> > On Wed, Jun 28, 2023 at 11:29 AM Sebastian Huber
> > <sebastian.huber at embedded-brains.de
> > <mailto:sebastian.huber at embedded-brains.de>> wrote:
> >     On 28.06.23 18:17, Joel Sherrill wrote:
> >      > On Wed, Jun 28, 2023 at 11:07 AM Sebastian Huber
> >     <mailto:sebastian.huber at embedded-brains.de>>> wrote:
> >      >     On 28.06.23 18:05, Joel Sherrill wrote:
> >      >      > The only use was in a test.
> >      >     This function is used by this patch set:
> >      > https://lists.rtems.org/pipermail/devel/2023-June/075497.html
> >     <https://lists.rtems.org/pipermail/devel/2023-June/075497.html>
> >     <https://lists.rtems.org/pipermail/devel/2023-June/075497.html>>
> >      > (1) Not in the source repository
> >     I didn't expect that the BSP update integration takes about two
> years.
> >      > (2) Even if it was, this code does not belong in the score. It
> looks
> >      > more like BSP support code that some drivers need.
> >     Where would you place this code?
> > If you want it on the cpukit side, dev/shared maybe. Otherwise,
> bsps/shared.
> Ok, I move it to cpukit/dev/io. At some point in time we probably need a
> bus space API.
Thanks. I am picking at moving all printk related functions into a single
location.
rtems/score/io.h really should not exist. Do you have any suggestions for
a more appropriate location and prefix for _IO_Base64url?
If it really is private as indicated by the _IO_ prefix, then it should not
be used where it is in the code. It needs a real public facing name and a
better location.
--joel
> embedded brains GmbH
> Herr Sebastian HUBER
> Dornierstr. 4
> 82178 Puchheim
> Germany
> email: sebastian.huber at embedded-brains.de
> phone: +49-89-18 94 741 - 16
> fax:   +49-89-18 94 741 - 08
> Registergericht: Amtsgericht München
> Registernummer: HRB 157899
> Vertretungsberechtigte Geschäftsführer: Peter Rasmussen, Thomas Dörfler
> Unsere Datenschutzerklärung finden Sie hier:
> https://embedded-brains.de/datenschutzerklaerung/
URL: <http://lists.rtems.org/pipermail/devel/attachments/20230628/2b717c1b/attachment.htm>
