[PATCH rtems] Remove unused _IO_Relax
Sebastian Huber
Wed Jun 28 17:17:37 UTC 2023
On 28.06.23 19:02, Joel Sherrill wrote:
> On Wed, Jun 28, 2023 at 11:29 AM Sebastian Huber
> <sebastian.huber at embedded-brains.de
> <mailto:sebastian.huber at embedded-brains.de>> wrote:
> On 28.06.23 18:17, Joel Sherrill wrote:
> > On Wed, Jun 28, 2023 at 11:07 AM Sebastian Huber
> <mailto:sebastian.huber at embedded-brains.de>>> wrote:
> > On 28.06.23 18:05, Joel Sherrill wrote:
> > > The only use was in a test.
> > This function is used by this patch set:
> > https://lists.rtems.org/pipermail/devel/2023-June/075497.html
> <https://lists.rtems.org/pipermail/devel/2023-June/075497.html>
> <https://lists.rtems.org/pipermail/devel/2023-June/075497.html>>
> > (1) Not in the source repository
> I didn't expect that the BSP update integration takes about two years.
> > (2) Even if it was, this code does not belong in the score. It looks
> > more like BSP support code that some drivers need.
> Where would you place this code?
> If you want it on the cpukit side, dev/shared maybe. Otherwise, bsps/shared.
Ok, I move it to cpukit/dev/io. At some point in time we probably need a
bus space API.
embedded brains GmbH
Herr Sebastian HUBER
Dornierstr. 4
82178 Puchheim
Germany
phone: +49-89-18 94 741 - 16
fax: +49-89-18 94 741 - 08
Registernummer: HRB 157899
