Tool versions for RTEMS 6.1 release?
Fri Jun 30 16:57:59 UTC 2023
On Fri, Jun 30, 2023 at 1:26 AM Sebastian Huber <
> Hello,
> it seems the RTEMS 6.1 release is getting closer. We should think about
> the tool versions for the release.
> For GCC, my preferred choice would be GCC 13.2:
> https://gcc.gnu.org/pipermail/gcc/2023-June/241838.html
> In GCC 12 a big change was enabling the vectorization support with -O2.
> This should have stabilized in GCC 13. GCC 13 contains some
> RTEMS-specific improvements for Ada.
I think I am generally ok with moving to 13.2 since we want to be reasonably
current when the branch happens.
Do you know of any Ada users with Adacore support for GNAT/RTEMS?
I am aware of one case and they are using GCC 11 as a base so we already
have a mismatch. The user builds RSB tools with TLS disabled for
compatibility.
 I know this isn't a community concern but if we have more Ada users, we
want to do
right by them.
I also was asked about using FORTRAN recently.
I'd like to say the same thing about Rust users. :)
> For Binutils and GDB I would just use the latest release available at
> the RTEMS 6 branch point.
> embedded brains GmbH
> Herr Sebastian HUBER
> Dornierstr. 4
> 82178 Puchheim
> Germany
> email: sebastian.huber at embedded-brains.de
> phone: +49-89-18 94 741 - 16
> fax:   +49-89-18 94 741 - 08
> Registergericht: Amtsgericht München
> Registernummer: HRB 157899
> Vertretungsberechtigte Geschäftsführer: Peter Rasmussen, Thomas Dörfler
> Unsere Datenschutzerklärung finden Sie hier:
> https://embedded-brains.de/datenschutzerklaerung/
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20230630/01ef98c4/attachment.htm>
