Tool versions for RTEMS 6.1 release?
Sam Price
thesamprice at gmail.com
Fri Jun 30 17:20:09 UTC 2023
How hard are the microblaze patches going to be to apply?
On Fri, Jun 30, 2023 at 1:19 PM Kinsey Moore <kinsey.moore at oarcorp.com>
wrote:
> On Fri, Jun 30, 2023 at 11:58 AM Joel Sherrill <joel at rtems.org> wrote:
>> On Fri, Jun 30, 2023 at 1:26 AM Sebastian Huber <
>> sebastian.huber at embedded-brains.de> wrote:
>>> Hello,
>>> it seems the RTEMS 6.1 release is getting closer. We should think about
>>> the tool versions for the release.
>>> For GCC, my preferred choice would be GCC 13.2:
>>> https://gcc.gnu.org/pipermail/gcc/2023-June/241838.html
>>> In GCC 12 a big change was enabling the vectorization support with -O2.
>>> This should have stabilized in GCC 13. GCC 13 contains some
>>> RTEMS-specific improvements for Ada.
>> I think I am generally ok with moving to 13.2 since we want to be
>> reasonably
>> current when the branch happens.
>> Do you know of any Ada users with Adacore support for GNAT/RTEMS?
>> I am aware of one case and they are using GCC 11 as a base so we already
>> have a mismatch. The user builds RSB tools with TLS disabled for
>> compatibility.
>> I know this isn't a community concern but if we have more Ada users, we
>> want to do
>> right by them.
>> I also was asked about using FORTRAN recently.
>> I'd like to say the same thing about Rust users. :)
>>> For Binutils and GDB I would just use the latest release available at
>>> the RTEMS 6 branch point.
> Be aware that I have recently rolled 6.1 binutils back from 2.40 to 2.39
> due to a regression in the AArch64 toolchain. The latest release is still
> 2.40, so please don't roll that forward until the 2.41 release is out and
> is verified to have the fix.
> Kinsey
> devel mailing list
> devel at rtems.org
Sincerely,
Sam Price
URL: <http://lists.rtems.org/pipermail/devel/attachments/20230630/967482ec/attachment-0001.htm>
