CAN driver implementation for Xilinx Zynq
Carlo.Brokering at dlr.de
Wed Mar 1 10:14:08 UTC 2023
Hello,
As part of an internship at the German Aerospace Center, I am currently working on the implementation of a CAN driver for a Xilinx Zynq SoC. For this I used the existing CAN framework /dev/can/can.h. A merge request will follow soon.
Here's what I'd like to add to the framework if it hasn't already been done:
* RxFIFO. Currently can_bus_read only stores the latest CAN message in can_bus->can_rx_msg.
There is a FIXME note on this in can.c, line 188, but I couldn't find an implementation of it.
* ioctl functionality. can_bus_ioctl does not forward the commands and arguments to can_dev_ops->dev_ioctl.
Is there a reason for that? I propose a command enum that would provide consistency.
@Prashanth S (fishesprashanth at gmail.com) have you already worked on these points?
Thanks everyone for your feedback!
Best regards
Carlo Brokering
URL: <http://lists.rtems.org/pipermail/devel/attachments/20230301/3c17b548/attachment.htm>
