[PATCH rtems-source-builder 2/2] 6/rtems-default.bset: Update binutils version to 2.40
Joel Sherrill
joel at rtems.org
Thu Mar 2 15:02:04 UTC 2023
On Thu, Mar 2, 2023 at 8:07 AM Sebastian Huber <
> Hello Joel,
> it seems that the update to Binutils 2.40 causes some issues on aarch64:
> 15:06:49 runner ['/opt/rtems/6-test/bin/aarch64-rtems6-gcc',
> 'testsuites/sptests/spconfig01/init.c.682.o',
> '-o/tmp/sh/b-rtems/aarch64/a53_ilp32_qemu/testsuites/sptests/spconfig01.exe',
> '-Wl,-Bstatic', '-L.', '-lrtemscpu', '-lrtemsbsp', '-lrtemstest',
> '-Wl,-Bdynamic', '-qrtems', '-mcpu=cortex-a53', '-mabi=ilp32',
> '-Wl,--gc-sections',
> '-L/home/EB/sebastian_h/src/rtems/bsps/aarch64/shared/start',
> '-L/home/EB/sebastian_h/src/rtems/bsps/aarch64/a53/start',
> '-Wl,--wrap=printf', '-Wl,--wrap=puts', '-Wl,--wrap=putchar']
> /opt/rtems/6-test/lib/gcc/aarch64-rtems6/12.2.1/../../../../aarch64-rtems6/bin/ld:
> warning:
> /opt/rtems/6-test/lib/gcc/aarch64-rtems6/12.2.1/../../../../aarch64-rtems6/lib/ilp32/libc.a(libc_a-memcmp.o):
> corrupt GNU_PROPERTY_TYPE (5) size: 0x10
> warning:
> /opt/rtems/6-test/lib/gcc/aarch64-rtems6/12.2.1/../../../../aarch64-rtems6/lib/ilp32/libc.a(libc_a-memcpy.o):
> warning:
> /opt/rtems/6-test/lib/gcc/aarch64-rtems6/12.2.1/../../../../aarch64-rtems6/lib/ilp32/libc.a(libc_a-memset.o):
> warning:
> /opt/rtems/6-test/lib/gcc/aarch64-rtems6/12.2.1/../../../../aarch64-rtems6/lib/ilp32/libc.a(libc_a-strcmp.o):
> warning:
> /opt/rtems/6-test/lib/gcc/aarch64-rtems6/12.2.1/../../../../aarch64-rtems6/lib/ilp32/libc.a(libc_a-strcpy.o):
> warning:
> /opt/rtems/6-test/lib/gcc/aarch64-rtems6/12.2.1/../../../../aarch64-rtems6/lib/ilp32/libc.a(libc_a-strlen.o):
> warning:
> has a LOAD segment with RWX permissions
> testsuites/sptests/spconfig01/init.c.682.o: in function
> `test_stack_config':
> /home/EB/sebastian_h/src/rtems/testsuites/sptests/spconfig01/init.c:89:
> undefined reference to `no symbol'
> collect2: error: ld returned 1 exit status
Did you look to see if this has been reported to binutils?
If there is no patch, you could see if it happens with 2.39. We really
should be using
something newer than 2.38.
I won't have time to look into this soon. Maybe Kinsey has some ideas.
--joel
> embedded brains GmbH
> Herr Sebastian HUBER
> Dornierstr. 4
> 82178 Puchheim
> Germany
> email: sebastian.huber at embedded-brains.de
> phone: +49-89-18 94 741 - 16
> fax: +49-89-18 94 741 - 08
> Registergericht: Amtsgericht München
> Registernummer: HRB 157899
> Vertretungsberechtigte Geschäftsführer: Peter Rasmussen, Thomas Dörfler
> Unsere Datenschutzerklärung finden Sie hier:
> https://embedded-brains.de/datenschutzerklaerung/
URL: <http://lists.rtems.org/pipermail/devel/attachments/20230302/cea8e58f/attachment.htm>
