[PATCH rtems-source-builder 2/2] 6/rtems-default.bset: Update binutils version to 2.40
Kinsey Moore kinsey.moore at oarcorp.com
Thu Mar 2 15:08:24 UTC 2023
On Thu, Mar 2, 2023 at 8:07 AM Sebastian Huber <
> Hello Joel,
> it seems that the update to Binutils 2.40 causes some issues on aarch64:
> 15:06:49 runner ['/opt/rtems/6-test/bin/aarch64-rtems6-gcc',
> 'testsuites/sptests/spconfig01/init.c.682.o',
> '-o/tmp/sh/b-rtems/aarch64/a53_ilp32_qemu/testsuites/sptests/spconfig01.exe',
> '-Wl,-Bstatic', '-L.', '-lrtemscpu', '-lrtemsbsp', '-lrtemstest',
> '-Wl,-Bdynamic', '-qrtems', '-mcpu=cortex-a53', '-mabi=ilp32',
> '-Wl,--gc-sections',
> '-L/home/EB/sebastian_h/src/rtems/bsps/aarch64/shared/start',
> '-L/home/EB/sebastian_h/src/rtems/bsps/aarch64/a53/start',
> '-Wl,--wrap=printf', '-Wl,--wrap=puts', '-Wl,--wrap=putchar']
> /opt/rtems/6-test/lib/gcc/aarch64-rtems6/12.2.1/../../../../aarch64-rtems6/bin/ld:
> warning:
> /opt/rtems/6-test/lib/gcc/aarch64-rtems6/12.2.1/../../../../aarch64-rtems6/lib/ilp32/libc.a(libc_a-memcmp.o):
> corrupt GNU_PROPERTY_TYPE (5) size: 0x10
> warning:
> /opt/rtems/6-test/lib/gcc/aarch64-rtems6/12.2.1/../../../../aarch64-rtems6/lib/ilp32/libc.a(libc_a-memcpy.o):
> warning:
> /opt/rtems/6-test/lib/gcc/aarch64-rtems6/12.2.1/../../../../aarch64-rtems6/lib/ilp32/libc.a(libc_a-memset.o):
> warning:
> /opt/rtems/6-test/lib/gcc/aarch64-rtems6/12.2.1/../../../../aarch64-rtems6/lib/ilp32/libc.a(libc_a-strcmp.o):
> warning:
> /opt/rtems/6-test/lib/gcc/aarch64-rtems6/12.2.1/../../../../aarch64-rtems6/lib/ilp32/libc.a(libc_a-strcpy.o):
> warning:
> /opt/rtems/6-test/lib/gcc/aarch64-rtems6/12.2.1/../../../../aarch64-rtems6/lib/ilp32/libc.a(libc_a-strlen.o):
> warning:
> has a LOAD segment with RWX permissions
> testsuites/sptests/spconfig01/init.c.682.o: in function
> `test_stack_config':
> /home/EB/sebastian_h/src/rtems/testsuites/sptests/spconfig01/init.c:89:
> undefined reference to `no symbol'
> collect2: error: ld returned 1 exit status
The corrupt GNU_PROPERTY_TYPE (5) warnings are known and do not affect
functionality. They were introduced in binutils sometime after adding the
ILP32 ABI support. The undefined reference errors are new, but the
spconfig01 test was originally disabled because it wouldn't compile due to
toolchain issues. I wonder if this is a regression of that same issue.
Kinsey
URL: <http://lists.rtems.org/pipermail/devel/attachments/20230302/ff1cc80b/attachment-0001.htm>
