[PATCH] bsps/riscv: Clear interrupt complete before disable
Padmarao.Begari at microchip.com
Fri Mar 3 14:55:18 UTC 2023
Hi Sebastian,
> On Thu, 2023-03-02 at 15:18 +0100, Sebastian Huber wrote:
> On 27.02.23 16:51, Padmarao Begari wrote:
> > The interrupt complete should clear with the interrupt
> > number before disabling the interrupt in the PLIC to
> > get the next interrupt.
> Which problem does this patch address?
The problem occurs when the interrupt register(enabled) in the RTEMS-
LIBBSD drivers and want to serve the interrupt subroutine in the RTEMS.
Example : CGEM driver
When the application running to test the CGEM driver with RTEMS +
RTEMS-LIBBSD, The interrupt is occurred while transmiting the ethernet
pocket, the RTEMS is received the interrupt but not served with the
register interrupt subroutine instead it disable the interrupt and set
the "RTEMS_EVENT_SYSTEM_SERVER", while completing the ISR it is
clearing the interrupt complete register but there is no effect and the
next transmit pocket intereupt is not occurred because the interrupt is
disabled before the interrupt complete clear.
RISC-V interrupt stacktrace
_RISCV_Exception_handler()
_RISCV_Interrupt_dispatch()
bsp_interrupt_handler_dispatch_unchecked()
bsp_interrupt_dispatch_entries()
( *entry->handler )( entry->arg ); -> bsp_interrupt_server_trigger()
bsp_interrupt_is_valid_vector()
bsp_interrupt_vector_disable()
rtems_event_system_send()
Regards
Padmarao
> embedded brains GmbH
> Herr Sebastian HUBER
> Dornierstr. 4
> 82178 Puchheim
> Germany
> email: sebastian.huber at embedded-brains.de
> phone: +49-89-18 94 741 - 16
> fax: +49-89-18 94 741 - 08
> Registergericht: Amtsgericht München
> Registernummer: HRB 157899
> Vertretungsberechtigte Geschäftsführer: Peter Rasmussen, Thomas
> Dörfler
> Unsere Datenschutzerklärung finden Sie hier:
> https://embedded-brains.de/datenschutzerklaerung/
