[PATCH] bsps/riscv: Clear interrupt complete before disable
Padmarao.Begari at microchip.com Padmarao.Begari at microchip.com
Mon Mar 6 12:00:43 UTC 2023
> On Mon, 2023-03-06 at 11:19 +0100, Sebastian Huber wrote:
> On 06.03.23 10:24, Padmarao.Begari at microchip.com wrote:
> > Hi Sebastian,
> > > On Mon, 2023-03-06 at 09:41 +0100, Sebastian Huber wrote:
> > > On 06.03.23 09:37, Padmarao.Begari at microchip.com wrote:
> > > > > Is
> > > > > the claim complete message ignored if the interrupt is
> > > > > disabled?
> > > > Yes.
> > > Is this an intended and documented behaviour of the PLIC?
> > Not documented
> Is this a common PLIC behaviour or just the case for the MicroChip
> implementation?
It's a common PLIC behaviour.
Regards
Padmarao
> > >   This is a
> > > hardware bug from my point of view. If we really need a software
> > > workround just for the PLIC to work with the interrupt server,
> > > then
> > > we
> > > should add a new function for this and keep the interrupt disable
> > > as
> > > is.
> > Ok
> You could for example add a bsp_interrupt_vector_server_disable()
> which
> defaults to bsp_interrupt_vector_disable().
> embedded brains GmbH
> Herr Sebastian HUBER
> Dornierstr. 4
> 82178 Puchheim
> Germany
> email: sebastian.huber at embedded-brains.de
> phone: +49-89-18 94 741 - 16
> fax:   +49-89-18 94 741 - 08
> Registergericht: Amtsgericht München
> Registernummer: HRB 157899
> Vertretungsberechtigte Geschäftsführer: Peter Rasmussen, Thomas
> Dörfler
> Unsere Datenschutzerklärung finden Sie hier:
> https://embedded-brains.de/datenschutzerklaerung/
