[PATCH 03/10] Clarify hardpps() parameter name and comment
Sebastian Huber
Tue Mar 7 06:32:13 UTC 2023
Since 32c203577a5e by phk in 1999 (Make even more of the PPSAPI
implementations generic), the "nsec" parameter of hardpps() is a time
difference and no longer a time point. Change the name to "delta_nsec"
and adjust the comment.
Remove comment about a clock tick adjustment which is no longer in the code.
Pull Request: https://github.com/freebsd/freebsd-src/pull/640
Reviewed by: imp
cpukit/score/src/kern_ntptime.c | 13 +++++--------
1 file changed, 5 insertions(+), 8 deletions(-)
diff --git a/cpukit/score/src/kern_ntptime.c b/cpukit/score/src/kern_ntptime.c
index 1233166a61..0d982e397b 100644
--- a/cpukit/score/src/kern_ntptime.c
+++ b/cpukit/score/src/kern_ntptime.c
@@ -862,11 +862,11 @@ hardupdate(offset)
* variables, except for the actual time and frequency variables, which
* are determined by this routine and updated atomically.
- * tsp - time at PPS
- * nsec - hardware counter at PPS
+ * tsp - time at current PPS event
+ * delta_nsec - time elapsed between the previous and current PPS event
void
-hardpps(struct timespec *tsp, long nsec)
+hardpps(struct timespec *tsp, long delta_nsec)
long u_sec, u_nsec, v_nsec; /* temps */
l_fp ftemp;
@@ -903,12 +903,9 @@ hardpps(struct timespec *tsp, long nsec)
* Compute the difference between the current and previous
* counter values. If the difference exceeds 0.5 s, assume it
- * has wrapped around, so correct 1.0 s. If the result exceeds
- * the tick interval, the sample point has crossed a tick
- * boundary during the last second, so correct the tick. Very
- * intricate.
+ * has wrapped around, so correct 1.0 s.
- u_nsec = nsec;
+ u_nsec = delta_nsec;
if (u_nsec > (NANOSECOND >> 1))
u_nsec -= NANOSECOND;
else if (u_nsec < -(NANOSECOND >> 1))
2.35.3
