[PATCH 01/10] kern_tc.c/cputick2usec()
Sebastian Huber
Tue Mar 7 06:32:11 UTC 2023
(which is used to calculate cputime from cpu ticks) has some imprecision and,
worse, huge timestep (about 20 minutes on 4GHz CPU) near 53.4 days of elapsed
time.
kern_time.c/cputick2timespec() (it is used for clock_gettime() for
querying process or thread consumed cpu time) Uses cputick2usec()
and then needlessly converting usec to nsec, obviously losing
precision even with fixed cputick2usec().
kern_time.c/kern_clock_getres() uses some weird (anyway wrong)
formula for getting cputick resolution.
PR: 262215
Reviewed by: gnn
Differential Revision: https://reviews.freebsd.org/D34558
cpukit/score/src/kern_tc.c | 12 +++---------
1 file changed, 3 insertions(+), 9 deletions(-)
diff --git a/cpukit/score/src/kern_tc.c b/cpukit/score/src/kern_tc.c
index 643026a1c8..8e43169934 100644
--- a/cpukit/score/src/kern_tc.c
+++ b/cpukit/score/src/kern_tc.c
@@ -2617,20 +2617,14 @@ cpu_tickrate(void)
* years) and in 64 bits at 4 GHz (146 years), but if we do a multiply
* before divide conversion (to retain precision) we find that the
* margin shrinks to 1.5 hours (one millionth of 146y).
- * With a three prong approach we never lose significant bits, no
- * matter what the cputick rate and length of timeinterval is.
uint64_t
cputick2usec(uint64_t tick)
- if (tick > 18446744073709551LL) /* floor(2^64 / 1000) */
- return (tick / (cpu_tickrate() / 1000000LL));
- else if (tick > 18446744073709LL) /* floor(2^64 / 1000000) */
- return ((tick * 1000LL) / (cpu_tickrate() / 1000LL));
- else
- return ((tick * 1000000LL) / cpu_tickrate());
+ uint64_t tr;
+ tr = cpu_tickrate();
+ return ((tick / tr) * 1000000ULL) + ((tick % tr) * 1000000ULL) / tr;
cpu_tick_f *cpu_ticks = tc_cpu_ticks;
2.35.3
