[PATCH 0/1] GSOC Contributor Opportunity
Gedare Bloom
gedare at rtems.org
Wed Mar 8 02:46:14 UTC 2023
Hi Ruturaj,
It helps if you can describe briefly the topics that interest you,
especially one email per topic idea can be most fruitful. That will
give you more likely feedback, because most of us have no clue what
the ticket numbers mean without clicking through. It would also be a
good idea to hop on the Discord and discuss the topic ideas of
interest in the #gsoc channel.
Two of those tickets relate to the build system and tooling. Chris may
know if they're still of interest.
Gedare
On Mon, Mar 6, 2023 at 9:51 PM Ruturaj Nanoti <nanotiruturaj at gmail.com> wrote:
> Hi All,
> My name is Ruturaj Nanoti, I am currently pursuing my Master's degree in
> Electrical Engineering at the University of Pennsylvania. I am interested
> in Firmware development for embedded system applications. I have worked
> with microcontrollers and development boards like STM32F4, RP2040 Pi Pico,
> Teensy 4.1, ItsyBitsy (nRF52840), etc. and also have experience with
> programming languages like C (both embedded and system level), C++,
> and Python.
> I came across RTEMS, while browsing through the organizations participating
> in GSOC this year, and found the work quite interesting and exciting. I would
> love to be a part of RTEMS and contribute to the project. Following are the
> links to some of the tasks, that I thought were quite exciting and I would
> really like to work on:
> - https://devel.rtems.org/ticket/4622
> - https://devel.rtems.org/ticket/3302
> - https://devel.rtems.org/ticket/4597
> I have built RTEMS and modified the `init.c` file under the `hello` testuite,
> to say something else instead of "Hello World" as mentioned in the documentation
> for students interested in GSOC. I also tested building the project after making
> the change and the build suceeds, so I am sending over the changes as a patch.
> Please let me know about the next steps, and I look forward to work with you all.
> Thank You
> Ruturaj Nanoti (1):
> testsuites/samples/hello/init.c: Modify the message in printf call
> testsuites/samples/hello/init.c | 3 ++-
> 1 file changed, 2 insertions(+), 1 deletion(-)
> 2.34.1
> devel mailing list
> devel at rtems.org
