[PATCH 1/1] testsuites/samples/hello/init.c: Modify the message in printf call
Ruturaj nanoti
nanotiruturaj at gmail.com
Wed Mar 8 03:38:14 UTC 2023
Hi Gedare,
Thank you for your response. I have sent an email with the screenshot
attached that shows the hello world example running in the SIS simulator.
Regards,
Ruturaj Nanoti
On Tue, Mar 7, 2023 at 9:44 PM Gedare Bloom <gedare at rtems.org> wrote:
> Thanks. Please email me and joel at rtems.org directly with a screenshot
> that shows you can run this modified hello world.
> On Mon, Mar 6, 2023 at 9:51 PM Ruturaj Nanoti <nanotiruturaj at gmail.com>
> wrote:
> > Changed the message printed out in the hello testsuite from
> > `Hello World` to `Hello RTEMS, from Ruturaj Nanoti!!` to
> > demonstrate the ability to work with the RTEMS project.
> > testsuites/samples/hello/init.c | 3 ++-
> > 1 file changed, 2 insertions(+), 1 deletion(-)
> > diff --git a/testsuites/samples/hello/init.c
> b/testsuites/samples/hello/init.c
> > index 83f6342ab3..2faff4a1ec 100644
> > --- a/testsuites/samples/hello/init.c
> > +++ b/testsuites/samples/hello/init.c
> > @@ -41,7 +41,8 @@ static rtems_task Init(
> > rtems_print_printer_fprintf_putc(&rtems_test_printer);
> > TEST_BEGIN();
> > - printf( "Hello World\n" );
> > + /* printf( "Hello World\n" ); */
> > + printf( "Hello RTEMS, from Ruturaj Nanoti!!\n" );
> > TEST_END();
> > rtems_test_exit( 0 );
> > 2.34.1
> > devel mailing list
> > devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20230307/49514b5b/attachment.htm>
