Help regarding Building x86_64 BSP
Frank Kühndel frank.kuehndel at embedded-brains.de
Wed Mar 8 10:08:01 UTC 2023
Hello,
On 3/8/23 01:42, Joel Sherrill wrote:
> Subject:
> Re: Help regarding Building x86_64 BSP
> From:
> Joel Sherrill <joel at rtems.org>
> Date:
> 3/8/23, 01:42
> To:
> Karel Gardas <karel at functional.vision>
> CC:
> "rtems-devel at rtems.org" <devel at rtems.org>
> Did you build the x86_64 tools and qemu using the RTEMS Source Builder?
The only information I can contribute to this discussion are the results
our Continuous Integration Server currently creates when building x86_64
tools with the RTEMS Source Builder:
almalinux 8.7: OK           [gcc (GCC) 8.5.0]
debian 11: OK               [gcc (Debian 10.2.1-6) 10.2.1]
fedora 37: Failure          [gcc (GCC) 12.2.1]
opensuse-leap 15.4: Failure [gcc (SUSE Linux) 12.2.1]
ubuntu 22.04: Failure       [gcc (Ubuntu 12.1.0-2ubuntu1~22.04) 12.1.0]
These builds were for RTEMS 6 and RSB
GIT_HEAD="bfed51462eafcb6a5102a2d6d80b233f3c6ef635".
The build failures all happen when `building:
grub2-2.06-x86_64-linux-gnu-1` which is the last build step. There are
several similar errors. These are two of them taken from the build log:
cc1: all warnings being treated as errors
util/mkimage.c: In function ‘grub_install_generate_image’:
util/mkimage.c:1386:41: error: dangling pointer to ‘tmp_’ may be used
[-Werror=d
angling-pointer=]
  1386 |         PE_OHDR (o32, o64, header_size) = grub_host_to_target32
(header_
size);
util/mkimage.c:857:28: note: ‘tmp_’ declared here
   857 |   __typeof__((o64)->field) tmp_;                \
util/mkimage.c:1386:9: note: in expansion of macro ‘PE_OHDR’
(header_
size);
util/mkimage.c:1387:40: error: dangling pointer to ‘tmp_’ may be used
[-Werror=d
angling-pointer=]
  1387 |         PE_OHDR (o32, o64, entry_addr) = grub_host_to_target32
(layout.s
tart_address);
util/mkimage.c:1387:9: note: in expansion of macro ‘PE_OHDR’
(layout.s
tart_address);
Maybe one needs a new version of grub sources for gcc 12?
Greetings
Frank
> On Tue, Mar 7, 2023, 11:39 AM Karel Gardas<karel at functional.vision>  wrote:
>> On 3/7/23 19:24, Karel Gardas wrote:
>>> On 3/7/23 15:05, Siddharth Khattar wrote:
>>>> Hello all,
>>>> So I was aiming to make a project to improve the amd64 BSP for RTEMS
>>>> (modify it according to ACPI standards along with other stuff) but
>>>> first I would need to build it. Unfortunately there was no way to
>>>> build it natively within RTEMS source. So, I needed to install QEMU
>>>> and had to build the UEFI firmware,OVMF by Tianocore in order to build
>>>> it.
>>> Indeed, they still list Ubutnu 16.04 LTS as a build OS. Hmm, I would go
>>> with VM for this. You need to build it just once...
>> Investigating more, it looks like qemu build those too, so there is no
>> need to deal with TianoCore alone anymore. My 7.2.0 install contains:
>> $ find qemu-7.2.0/share/qemu/ -name 'edk2*'
>> qemu-7.2.0/share/qemu/edk2-arm-code.fd
>> qemu-7.2.0/share/qemu/edk2-x86_64-code.fd
>> qemu-7.2.0/share/qemu/edk2-arm-vars.fd
>> qemu-7.2.0/share/qemu/edk2-i386-secure-code.fd
>> qemu-7.2.0/share/qemu/edk2-x86_64-secure-code.fd
>> qemu-7.2.0/share/qemu/edk2-aarch64-code.fd
>> qemu-7.2.0/share/qemu/edk2-i386-code.fd
>> qemu-7.2.0/share/qemu/edk2-i386-vars.fd
>> qemu-7.2.0/share/qemu/edk2-licenses.txt
>> Ditto for Qemu build by RSB. Will send you tarball of scripts I'm using
>> for building and running rtems.exe on those...
>> Karel
>> devel mailing list
>> devel at rtems.org
> devel mailing list
> devel at rtems.org
embedded brains GmbH
Herr Frank KÜHNDEL
Dornierstr. 4
82178 Puchheim
Germany
email: frank.kuehndel at embedded-brains.de
phone:  +49-89-18 94 741 - 23
mobile: +49-176-15 22 06 - 11
fax:    +49-89-18 94 741 - 08
Registernummer: HRB 157899
