Help regarding Building x86_64 BSP
Karel Gardas karel at functional.vision
Sun Mar 12 12:03:25 UTC 2023
On 3/8/23 11:08, Frank Kühndel wrote:
> Hello,
> On 3/8/23 01:42, Joel Sherrill wrote:
>> Subject:
>> Re: Help regarding Building x86_64 BSP
>> From:
>> Joel Sherrill <joel at rtems.org>
>> Date:
>> 3/8/23, 01:42
>> To:
>> Karel Gardas <karel at functional.vision>
>> CC:
>> "rtems-devel at rtems.org" <devel at rtems.org>
>> Did you build the x86_64 tools and qemu using the RTEMS Source Builder?
> The only information I can contribute to this discussion are the results
> our Continuous Integration Server currently creates when building x86_64
> tools with the RTEMS Source Builder:
> almalinux 8.7: OK           [gcc (GCC) 8.5.0]
> debian 11: OK               [gcc (Debian 10.2.1-6) 10.2.1]
> fedora 37: Failure          [gcc (GCC) 12.2.1]
> opensuse-leap 15.4: Failure [gcc (SUSE Linux) 12.2.1]
> ubuntu 22.04: Failure       [gcc (Ubuntu 12.1.0-2ubuntu1~22.04) 12.1.0]
> These builds were for RTEMS 6 and RSB
Just a remark to table above. Ubuntu 22.04 LTS default GCC is 11.x and
it's perfectly able to build x86_64 tools (tested by me).
On RHEL8, default gcc is 8.5.x and it should be ok.
On RHEL9, default gcc is 11.3.x and it should also be able to build
tools fine.
The only issue on RHELx is that makeinfo is missing so you either need
to install from different repo or by hand.
SLES testing in whatever form is out of my reach.
Karel
