[PATCH rtems-docs] c-user/chains: Correct iteration example code
Chris Johns
chrisj at rtems.org
Wed Mar 8 21:47:20 UTC 2023
On 9/3/2023 5:40 am, Kinsey Moore wrote:
> Casting the node returned by rtems_chain_head is incorrect. That node is
> owned by the control structure and use of it post-cast could cause
> memory corruption.
> c-user/chains.rst | 4 ++++
> 1 file changed, 4 insertions(+)
> diff --git a/c-user/chains.rst b/c-user/chains.rst
> index f518ef4..e791d10 100644
> --- a/c-user/chains.rst
> +++ b/c-user/chains.rst
> @@ -193,6 +193,10 @@ placed on another chain:
> rtems_chain_initialize_empty (out);
> node = rtems_chain_head (chain);
> + /* The node returned by rtems_chain_head() is owned by the chain */
> + node = node->next;
node = rtems_chain_next (node); ?
> while (!rtems_chain_is_tail (chain, node))
> bar = (foo*) node;
