[PATCH rtems-docs] c-user/chains: Correct iteration example code
Kinsey Moore
kinsey.moore at oarcorp.com
Wed Mar 8 20:40:49 UTC 2023
Casting the node returned by rtems_chain_head is incorrect. That node is
owned by the control structure and use of it post-cast could cause
memory corruption.
c-user/chains.rst | 4 ++++
1 file changed, 4 insertions(+)
diff --git a/c-user/chains.rst b/c-user/chains.rst
index f518ef4..e791d10 100644
--- a/c-user/chains.rst
+++ b/c-user/chains.rst
@@ -193,6 +193,10 @@ placed on another chain:
rtems_chain_initialize_empty (out);
node = rtems_chain_head (chain);
+ /* The node returned by rtems_chain_head() is owned by the chain */
+ node = node->next;
while (!rtems_chain_is_tail (chain, node))
bar = (foo*) node;
2.30.2
