[PATCH] 6/gdb: fix building on FreeBSD 13.1
Chris Johns
chrisj at rtems.org
Thu Mar 9 05:01:10 UTC 2023
On 9/3/2023 1:54 pm, Joel Sherrill wrote:
> I've followed the discussion with gdb and this is ok.
Thanks.
> I still question them
> installing that header file. The the patch you're adding fixes it by making
> local includes ahead. But I don't remember seeing an answer to the question of
> should the header file be installed anyway.
It is kind of awkward to sort out. I think there will be skews in versions when
installed binutils and gdb vary in age. I suppose it depends on how often the
file changes? I wonder how the package managers handle the clash if binutils and
gdb both install and package it?
> Ok to push
I will push it once I finish some more testing.
