[lwip 1/2] Fix build for arm/tms570 BSPs
Sebastian Huber
Thu Mar 9 12:13:09 UTC 2023
defs/bsps/arm/tms570_base.json | 6 ++++--
uLan/ports/driver/tms570_emac/eth_lwip.c | 15 +++++++++++----
uLan/ports/driver/tms570_emac/phy_dp83848h.c | 1 +
uLan/ports/driver/tms570_emac/phy_dp83848h.h | 2 ++
4 files changed, 18 insertions(+), 6 deletions(-)
diff --git a/defs/bsps/arm/tms570_base.json b/defs/bsps/arm/tms570_base.json
index 33cd969..050f77a 100644
--- a/defs/bsps/arm/tms570_base.json
+++ b/defs/bsps/arm/tms570_base.json
@@ -1,9 +1,11 @@
"header-paths-to-import": [
"uLan/ports/driver/tms570_emac",
- "uLan/ports/os"
+ "uLan/ports/os",
+ "cpsw/src/include"
"source-paths-to-import": [
- "uLan/ports/driver/tms570_emac"
+ "uLan/ports/driver/tms570_emac",
+ "cpsw/src"
diff --git a/uLan/ports/driver/tms570_emac/eth_lwip.c b/uLan/ports/driver/tms570_emac/eth_lwip.c
index 6105268..0315cdf 100644
--- a/uLan/ports/driver/tms570_emac/eth_lwip.c
+++ b/uLan/ports/driver/tms570_emac/eth_lwip.c
@@ -39,7 +39,7 @@
#include "netif/etharp.h" /* includes - lwip/ip.h, lwip/netif.h, lwip/ip_addr.h, lwip/pbuf.h */
#include "eth_lwip_default.h"
#include "eth_lwip.h"
-#include "beaglebone.h"
+#include "tms570_netif.h"
/* The lwIP network interface structure for the Ethernet EMAC. */
@@ -72,8 +72,13 @@ eth_lwip_get_dhcp_info(void)
-int8_t
-eth_lwip_init(uint8_t *mac_addr)
+int start_networking(
+ struct netif *net_interface,
+ ip_addr_t *ipaddr,
+ ip_addr_t *netmask,
+ ip_addr_t *gateway,
+ unsigned char *mac_addr
unsigned int instance_number = 0;
int8_t retVal = SUCCESS;
@@ -103,15 +108,17 @@ eth_lwip_init(uint8_t *mac_addr)
#endif
netif_tmp = netif_add(netif, &ip_addr, &net_mask, &gw_addr,
- NULL, ETH_LWIP_INIT_NETIF_FNC, tcpip_input);
+ NULL, tms570_eth_init_netif, tcpip_input);
if (netif_tmp == NULL)
return NETIF_ADD_ERR;
netif_set_default(netif);
+#if LWIP_NETIF_API
netifapi_netif_set_up(netif);
#if !STATIC_IP_ADDRESS
netifapi_dhcp_start(netif);
+#endif
#endif
return retVal;
diff --git a/uLan/ports/driver/tms570_emac/phy_dp83848h.c b/uLan/ports/driver/tms570_emac/phy_dp83848h.c
index d20f669..dec1011 100644
--- a/uLan/ports/driver/tms570_emac/phy_dp83848h.c
+++ b/uLan/ports/driver/tms570_emac/phy_dp83848h.c
@@ -34,6 +34,7 @@
#include "ti_drv_mdio.h"
#include "phy_dp83848h.h"
+#include "mdio.h"
#ifndef TRUE
diff --git a/uLan/ports/driver/tms570_emac/phy_dp83848h.h b/uLan/ports/driver/tms570_emac/phy_dp83848h.h
index 58d9f04..8ddb3ec 100644
--- a/uLan/ports/driver/tms570_emac/phy_dp83848h.h
+++ b/uLan/ports/driver/tms570_emac/phy_dp83848h.h
@@ -35,6 +35,8 @@
#ifndef __DRV_PHY_H
#define __DRV_PHY_H
+#include <bsp/ti_herc/reg_mdio.h>
#ifdef __cplusplus
extern "C" {
#endif
2.35.3
