[PATCH rtems-docs v2] c-user/chains: Correct iteration example code
Sebastian Huber
Thu Mar 9 07:01:30 UTC 2023
On 09.03.23 03:33, Kinsey Moore wrote:
> Casting the node returned by rtems_chain_head is incorrect. That node is
> owned by the control structure and use of it post-cast could cause
> memory corruption.
> c-user/chains.rst | 6 +++++-
> 1 file changed, 5 insertions(+), 1 deletion(-)
> diff --git a/c-user/chains.rst b/c-user/chains.rst
> index f518ef4..2044966 100644
> --- a/c-user/chains.rst
> +++ b/c-user/chains.rst
> @@ -193,10 +193,14 @@ placed on another chain:
> rtems_chain_initialize_empty (out);
> node = rtems_chain_head (chain);
> + /* The node returned by rtems_chain_head() is owned by the chain */
> + node = rtems_chain_next(node);
You can simply use rtems_chain_first() instead of this head/next
combination.
embedded brains GmbH
Herr Sebastian HUBER
Dornierstr. 4
82178 Puchheim
Germany
phone: +49-89-18 94 741 - 16
fax: +49-89-18 94 741 - 08
Registernummer: HRB 157899
