[PATCH rtems-docs v2] c-user/chains: Correct iteration example code
Kinsey Moore
kinsey.moore at oarcorp.com
Thu Mar 9 13:12:58 UTC 2023
On Thu, Mar 9, 2023 at 1:01 AM Sebastian Huber <
> On 09.03.23 03:33, Kinsey Moore wrote:
> > Casting the node returned by rtems_chain_head is incorrect. That node is
> > owned by the control structure and use of it post-cast could cause
> > memory corruption.
> > c-user/chains.rst | 6 +++++-
> > 1 file changed, 5 insertions(+), 1 deletion(-)
> > diff --git a/c-user/chains.rst b/c-user/chains.rst
> > index f518ef4..2044966 100644
> > --- a/c-user/chains.rst
> > +++ b/c-user/chains.rst
> > @@ -193,10 +193,14 @@ placed on another chain:
> > rtems_chain_initialize_empty (out);
> > node = rtems_chain_head (chain);
> > + /* The node returned by rtems_chain_head() is owned by the
> chain */
> > + node = rtems_chain_next(node);
> You can simply use rtems_chain_first() instead of this head/next
> combination.
Thanks, I'll make that improvement before committing!
Kinsey
URL: <http://lists.rtems.org/pipermail/devel/attachments/20230309/192767bd/attachment.htm>
