[lwip 1/2] Fix build for arm/tms570 BSPs
Kinsey Moore
kinsey.moore at oarcorp.com
Thu Mar 9 13:50:18 UTC 2023
The changes to TI sources for dp83848h should use the #ifdef __rtems__
convention since they will not be fully integrated into the rtemslwip
directory.
Kinsey
On Thu, Mar 9, 2023 at 6:13 AM Sebastian Huber <
> defs/bsps/arm/tms570_base.json | 6 ++++--
> uLan/ports/driver/tms570_emac/eth_lwip.c | 15 +++++++++++----
> uLan/ports/driver/tms570_emac/phy_dp83848h.c | 1 +
> uLan/ports/driver/tms570_emac/phy_dp83848h.h | 2 ++
> 4 files changed, 18 insertions(+), 6 deletions(-)
> diff --git a/defs/bsps/arm/tms570_base.json
> b/defs/bsps/arm/tms570_base.json
> index 33cd969..050f77a 100644
> --- a/defs/bsps/arm/tms570_base.json
> +++ b/defs/bsps/arm/tms570_base.json
> @@ -1,9 +1,11 @@
> "header-paths-to-import": [
> "uLan/ports/driver/tms570_emac",
> - "uLan/ports/os"
> + "uLan/ports/os",
> + "cpsw/src/include"
> "source-paths-to-import": [
> - "uLan/ports/driver/tms570_emac"
> + "uLan/ports/driver/tms570_emac",
> + "cpsw/src"
> diff --git a/uLan/ports/driver/tms570_emac/eth_lwip.c
> b/uLan/ports/driver/tms570_emac/eth_lwip.c
> index 6105268..0315cdf 100644
> --- a/uLan/ports/driver/tms570_emac/eth_lwip.c
> +++ b/uLan/ports/driver/tms570_emac/eth_lwip.c
> @@ -39,7 +39,7 @@
> #include "netif/etharp.h" /* includes - lwip/ip.h, lwip/netif.h,
> lwip/ip_addr.h, lwip/pbuf.h */
> #include "eth_lwip_default.h"
> #include "eth_lwip.h"
> -#include "beaglebone.h"
> +#include "tms570_netif.h"
> #include <stdio.h>
> /* The lwIP network interface structure for the Ethernet EMAC. */
> @@ -72,8 +72,13 @@ eth_lwip_get_dhcp_info(void)
> -int8_t
> -eth_lwip_init(uint8_t *mac_addr)
> +int start_networking(
> + struct netif *net_interface,
> + ip_addr_t *ipaddr,
> + ip_addr_t *netmask,
> + ip_addr_t *gateway,
> + unsigned char *mac_addr
> unsigned int instance_number = 0;
> int8_t retVal = SUCCESS;
> @@ -103,15 +108,17 @@ eth_lwip_init(uint8_t *mac_addr)
> #endif
> netif_tmp = netif_add(netif, &ip_addr, &net_mask, &gw_addr,
> - NULL, ETH_LWIP_INIT_NETIF_FNC, tcpip_input);
> + NULL, tms570_eth_init_netif, tcpip_input);
> if (netif_tmp == NULL)
> return NETIF_ADD_ERR;
> netif_set_default(netif);
> +#if LWIP_NETIF_API
> netifapi_netif_set_up(netif);
> #if !STATIC_IP_ADDRESS
> netifapi_dhcp_start(netif);
> +#endif
> #endif
> return retVal;
> diff --git a/uLan/ports/driver/tms570_emac/phy_dp83848h.c
> b/uLan/ports/driver/tms570_emac/phy_dp83848h.c
> index d20f669..dec1011 100644
> --- a/uLan/ports/driver/tms570_emac/phy_dp83848h.c
> +++ b/uLan/ports/driver/tms570_emac/phy_dp83848h.c
> @@ -34,6 +34,7 @@
> #include "ti_drv_mdio.h"
> #include "phy_dp83848h.h"
> +#include "mdio.h"
> #ifndef TRUE
> diff --git a/uLan/ports/driver/tms570_emac/phy_dp83848h.h
> b/uLan/ports/driver/tms570_emac/phy_dp83848h.h
> index 58d9f04..8ddb3ec 100644
> --- a/uLan/ports/driver/tms570_emac/phy_dp83848h.h
> +++ b/uLan/ports/driver/tms570_emac/phy_dp83848h.h
> @@ -35,6 +35,8 @@
> #ifndef __DRV_PHY_H
> #define __DRV_PHY_H
> +#include <bsp/ti_herc/reg_mdio.h>
> #ifdef __cplusplus
> extern "C" {
> #endif
> 2.35.3
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20230309/b46748db/attachment.htm>
