[PATCH rtems-source-builder] 6: Update MicroBlaze gdb to 12.1
Thu Mar 9 21:54:46 UTC 2023
On 9/3/2023 8:10 pm, Frank Kühndel wrote:
> Hello Chris,
> Hello Alex,
> On 3/8/23 20:51, Chris Johns wrote:
>> Subject:
>> Re: [PATCH rtems-source-builder] 6: Update MicroBlaze gdb to 12.1
>> From:
>> Chris Johns <chrisj at rtems.org>
>> Date:
>> 3/8/23, 20:51
>> To:
>> Alex White <alex.white at oarcorp.com>, devel at rtems.org
>> What hosts have you tested building this on?
>> I only ask as gdb-13 is not building on FeeBSD 13.1 for me.
> I tried Alex's patch on top of RSB bfed51462eafcb6a5102a2d6d80b233f3c6ef635 for
> RTEMS 6 and microblaze:
> almalinux 8.7: OK           [gcc (GCC) 8.5.0]
> debian 11: OK               [gcc (Debian 10.2.1-6) 10.2.1]
> fedora 37: OK               [gcc (GCC) 12.2.1]
> opensuse-leap 15.4: OK      [gcc (SUSE Linux) 12.2.1]
> ubuntu 22.04: OK            [gcc (Ubuntu 12.1.0-2ubuntu1~22.04) 12.1.0]
> With FreeBSD I cannot help, sorry. Also, the above containers use the latest OS
> versions. I did not test older ones. Moreover, Opensuse 15.4 does not use gcc 12
> by default but a much older compiler.
Thanks Frank, this is a great set of results.
This change is fine to push.
