Problem when in booting amd64 BSP
Karel Gardas
karel at functional.vision
Sun Mar 12 15:38:14 UTC 2023
Read https://www.mail-archive.com/devel@rtems.org/msg28484.html
Also, if you modify /boot/kernel/kernel on FBSD you can't really expect
it to boot back for you magically. You have basically sent FBSD kernel
to void...:-)
On 3/12/23 15:11, Siddharth Khattar wrote:
> Hello all, So recently I was trying to run the amd64 BSP of RTEMS in
> order to be able to test on it for my GSoC 2023 project and was
> following the guide on RTEMS User Manual 9.18, it took me a few days to
> follow all the steps on it but after finally putting the hello.exe file
> (built for x86_64 & amd64) and copying it into /boot/kernel/kernel of
> the FreeBSD 11.2 virtual system, it crashed and now doesn't boot up at
> all. I tried doing the same even on a FreeBSD 13 virtual machine but it
> had the same problem and didn't end up booting for me. I also
> double-checked everything to make sure I wasn't making a silly mistake
> or having a small problem. The attached screenshot is from trying to
> boot it on the FreeBSD 13 virtual machine. If somebody has some idea why
> this error is occurring, I would really appreciate their help!
> devel mailing list
> devel at rtems.org
