[PATCH v2] doxygen: Add groups for related test suites
Mon Mar 13 13:16:34 UTC 2023
v2: Adjust group membership of related test suites.
 cpukit/doxygen/top-level-groups.h             | 24 +++++++++++++++++++
 testsuites/unit/ts-unit-no-clock-0.c          |  2 +-
 ...boot-processor-not-assigned-to-scheduler.c |  2 +-
 .../ts-fatal-idle-thread-create-failed.c      |  2 +-
 .../ts-fatal-idle-thread-stack-too-small.c    |  2 +-
 .../ts-fatal-init-task-construct-failed.c     |  2 +-
 ...ts-fatal-mandatory-processor-not-present.c |  2 +-
 ...scheduler-requires-exactly-one-processor.c |  2 +-
 testsuites/validation/ts-fatal-smp.c          |  2 +-
 ...atal-start-of-mandatory-processor-failed.c |  2 +-
 .../ts-fatal-start-on-not-online-processor.c  |  2 +-
 .../validation/ts-fatal-too-large-tls-size.c  |  2 +-
 .../validation/ts-performance-no-clock-0.c    |  2 +-
 testsuites/validation/ts-terminate.c          |  2 +-
 testsuites/validation/ts-userext.c            |  2 +-
 testsuites/validation/ts-validation-0.c       |  2 +-
 testsuites/validation/ts-validation-1.c       |  2 +-
 testsuites/validation/ts-validation-acfg-0.c  |  2 +-
 testsuites/validation/ts-validation-acfg-1.c  |  2 +-
 testsuites/validation/ts-validation-cache.c   |  2 +-
 testsuites/validation/ts-validation-intr.c    |  2 +-
 .../validation/ts-validation-io-kernel.c      |  2 +-
 .../validation/ts-validation-no-clock-0.c     |  2 +-
 testsuites/validation/ts-validation-non-smp.c |  2 +-
 .../validation/ts-validation-one-cpu-0.c      |  2 +-
 .../validation/ts-validation-one-cpu-1.c      |  2 +-
 .../validation/ts-validation-smp-one-cpu-0.c  |  2 +-
 .../validation/ts-validation-smp-only-0.c     |  2 +-
 .../validation/ts-validation-smp-only-2.c     |  2 +-
 .../validation/ts-validation-timecounter-0.c  |  2 +-
 .../validation/ts-validation-timecounter-1.c  |  2 +-
 .../ts-validation-timecounter-smp-0.c         |  2 +-
 testsuites/validation/ts-validation-tls-0.c   |  2 +-
 testsuites/validation/ts-validation-tls-1.c   |  2 +-
 34 files changed, 57 insertions(+), 33 deletions(-)
diff --git a/cpukit/doxygen/top-level-groups.h b/cpukit/doxygen/top-level-groups.h
index 8a439feee1..25bf8faae2 100644
--- a/cpukit/doxygen/top-level-groups.h
+++ b/cpukit/doxygen/top-level-groups.h
@@ -63,3 +63,27 @@
  * @brief This group contains the test suites.
+ * @defgroup RTEMSTestSuitesPerformance Performance Test Suites
+ * @ingroup RTEMSTestSuites
+ * @brief This group contains the test suites related to performance tests.
+ * @defgroup RTEMSTestSuitesUnit Unit Test Suites
+ * @brief This group contains the test suites related to unit tests.
+ * @defgroup RTEMSTestSuitesValidation Validation Test Suites
+ * @brief This group contains the test suites related to validation tests.
diff --git a/testsuites/unit/ts-unit-no-clock-0.c b/testsuites/unit/ts-unit-no-clock-0.c
index 4bbb0b8000..a494eea074 100644
--- a/testsuites/unit/ts-unit-no-clock-0.c
+++ b/testsuites/unit/ts-unit-no-clock-0.c
@@ -57,7 +57,7 @@
  * @defgroup TestsuitesUnitNoClock0 spec:/testsuites/unit-no-clock-0
- * @ingroup RTEMSTestSuites
+ * @ingroup RTEMSTestSuitesUnit
  * @brief This general purpose unit test suite provides enough resources to run
  *   basic tests without a Clock Driver for all specified managers and
diff --git a/testsuites/validation/ts-fatal-boot-processor-not-assigned-to-scheduler.c b/testsuites/validation/ts-fatal-boot-processor-not-assigned-to-scheduler.c
index dd1bae545c..51dd22fc1d 100644
--- a/testsuites/validation/ts-fatal-boot-processor-not-assigned-to-scheduler.c
+++ b/testsuites/validation/ts-fatal-boot-processor-not-assigned-to-scheduler.c
@@ -61,7 +61,7 @@
  * @defgroup TestsuitesFatalBootProcessorNotAssignedToScheduler \
  *   spec:/testsuites/fatal-boot-processor-not-assigned-to-scheduler
+ * @ingroup RTEMSTestSuitesValidation
  * @brief This validation test suite uses an application configuration which
  *   triggers a fatal error during system initialization.
diff --git a/testsuites/validation/ts-fatal-idle-thread-create-failed.c b/testsuites/validation/ts-fatal-idle-thread-create-failed.c
index d09a8aeaf9..1bbf06df00 100644
--- a/testsuites/validation/ts-fatal-idle-thread-create-failed.c
+++ b/testsuites/validation/ts-fatal-idle-thread-create-failed.c
@@ -60,7 +60,7 @@
  * @defgroup TestsuitesFatalIdleThreadCreateFailed \
  *   spec:/testsuites/fatal-idle-thread-create-failed
  * @brief This validation test suite contains a test case which is triggered by
  *   a fatal error during system initialization.
diff --git a/testsuites/validation/ts-fatal-idle-thread-stack-too-small.c b/testsuites/validation/ts-fatal-idle-thread-stack-too-small.c
index f0689b286e..b5dd10c960 100644
--- a/testsuites/validation/ts-fatal-idle-thread-stack-too-small.c
+++ b/testsuites/validation/ts-fatal-idle-thread-stack-too-small.c
@@ -60,7 +60,7 @@
  * @defgroup TestsuitesFatalIdleThreadStackTooSmall \
  *   spec:/testsuites/fatal-idle-thread-stack-too-small
  * @brief This validation test suite contains a test case which triggers a
  *   fatal error during system initialization.
diff --git a/testsuites/validation/ts-fatal-init-task-construct-failed.c b/testsuites/validation/ts-fatal-init-task-construct-failed.c
index c7ac50adc6..a2a1c8668e 100644
--- a/testsuites/validation/ts-fatal-init-task-construct-failed.c
+++ b/testsuites/validation/ts-fatal-init-task-construct-failed.c
@@ -60,7 +60,7 @@
  * @defgroup TestsuitesFatalInitTaskConstructFailed \
  *   spec:/testsuites/fatal-init-task-construct-failed
diff --git a/testsuites/validation/ts-fatal-mandatory-processor-not-present.c b/testsuites/validation/ts-fatal-mandatory-processor-not-present.c
index c4a4f84b40..855b67a7d6 100644
--- a/testsuites/validation/ts-fatal-mandatory-processor-not-present.c
+++ b/testsuites/validation/ts-fatal-mandatory-processor-not-present.c
@@ -61,7 +61,7 @@
  * @defgroup TestsuitesFatalMandatoryProcessorNotPresent \
  *   spec:/testsuites/fatal-mandatory-processor-not-present
diff --git a/testsuites/validation/ts-fatal-scheduler-requires-exactly-one-processor.c b/testsuites/validation/ts-fatal-scheduler-requires-exactly-one-processor.c
index 590af0249f..fe86e34bd0 100644
--- a/testsuites/validation/ts-fatal-scheduler-requires-exactly-one-processor.c
+++ b/testsuites/validation/ts-fatal-scheduler-requires-exactly-one-processor.c
@@ -61,7 +61,7 @@
  * @defgroup TestsuitesFatalSchedulerRequiresExactlyOneProcessor \
  *   spec:/testsuites/fatal-scheduler-requires-exactly-one-processor
diff --git a/testsuites/validation/ts-fatal-smp.c b/testsuites/validation/ts-fatal-smp.c
index 8f4c20b0d8..d1455a5148 100644
--- a/testsuites/validation/ts-fatal-smp.c
+++ b/testsuites/validation/ts-fatal-smp.c
@@ -60,7 +60,7 @@
  * @defgroup TestsuitesFatalSmp spec:/testsuites/fatal-smp
  *   SMP-specific fatal errors.
diff --git a/testsuites/validation/ts-fatal-start-of-mandatory-processor-failed.c b/testsuites/validation/ts-fatal-start-of-mandatory-processor-failed.c
index b65afae5c2..38ee0f180d 100644
--- a/testsuites/validation/ts-fatal-start-of-mandatory-processor-failed.c
+++ b/testsuites/validation/ts-fatal-start-of-mandatory-processor-failed.c
@@ -61,7 +61,7 @@
  * @defgroup TestsuitesFatalStartOfMandatoryProcessorFailed \
  *   spec:/testsuites/fatal-start-of-mandatory-processor-failed
diff --git a/testsuites/validation/ts-fatal-start-on-not-online-processor.c b/testsuites/validation/ts-fatal-start-on-not-online-processor.c
index 1630952234..765ae2d8d8 100644
--- a/testsuites/validation/ts-fatal-start-on-not-online-processor.c
+++ b/testsuites/validation/ts-fatal-start-on-not-online-processor.c
@@ -61,7 +61,7 @@
  * @defgroup TestsuitesFatalStartOnNotOnlineProcessor \
  *   spec:/testsuites/fatal-start-on-not-online-processor
diff --git a/testsuites/validation/ts-fatal-too-large-tls-size.c b/testsuites/validation/ts-fatal-too-large-tls-size.c
index 7b3e06f92a..3687f9a234 100644
--- a/testsuites/validation/ts-fatal-too-large-tls-size.c
+++ b/testsuites/validation/ts-fatal-too-large-tls-size.c
@@ -60,7 +60,7 @@
  * @defgroup TestsuitesFatalTooLargeTlsSize \
  *   spec:/testsuites/fatal-too-large-tls-size
diff --git a/testsuites/validation/ts-performance-no-clock-0.c b/testsuites/validation/ts-performance-no-clock-0.c
index ecff6395ab..1cbb258413 100644
--- a/testsuites/validation/ts-performance-no-clock-0.c
+++ b/testsuites/validation/ts-performance-no-clock-0.c
@@ -60,7 +60,7 @@
  * @defgroup TestsuitesPerformanceNoClock0 \
  *   spec:/testsuites/performance-no-clock-0
+ * @ingroup RTEMSTestSuitesPerformance
  * @brief This general purpose performance test suite provides enough resources
  *   to run basic performance tests for all specified managers and functions.
diff --git a/testsuites/validation/ts-terminate.c b/testsuites/validation/ts-terminate.c
index 95a6fed64c..dc9c953472 100644
--- a/testsuites/validation/ts-terminate.c
+++ b/testsuites/validation/ts-terminate.c
@@ -59,7 +59,7 @@
  * @defgroup TestsuitesTerminate spec:/testsuites/terminate
  * @brief This validation test suite contains a test case for the system
  *   termination procedure.
diff --git a/testsuites/validation/ts-userext.c b/testsuites/validation/ts-userext.c
index 7d2c190cb1..595f37a2a6 100644
--- a/testsuites/validation/ts-userext.c
+++ b/testsuites/validation/ts-userext.c
@@ -59,7 +59,7 @@
  * @defgroup TestsuitesUserext spec:/testsuites/userext
  * @brief This validation test suite contains a test cases related to the
  *   invocation of user extensions.
diff --git a/testsuites/validation/ts-validation-0.c b/testsuites/validation/ts-validation-0.c
index dda79c4427..cca15c7c6d 100644
--- a/testsuites/validation/ts-validation-0.c
+++ b/testsuites/validation/ts-validation-0.c
@@ -57,7 +57,7 @@
  * @defgroup TestsuitesValidation0 spec:/testsuites/validation-0
  * @brief This general purpose validation test suite provides enough resources
  *   to run basic tests for all specified managers and functions.
diff --git a/testsuites/validation/ts-validation-1.c b/testsuites/validation/ts-validation-1.c
index f1a67e16a3..0ded0a18be 100644
--- a/testsuites/validation/ts-validation-1.c
+++ b/testsuites/validation/ts-validation-1.c
@@ -57,7 +57,7 @@
  * @defgroup TestsuitesValidation1 spec:/testsuites/validation-1
diff --git a/testsuites/validation/ts-validation-acfg-0.c b/testsuites/validation/ts-validation-acfg-0.c
index 9fe6793231..3c033bbecb 100644
--- a/testsuites/validation/ts-validation-acfg-0.c
+++ b/testsuites/validation/ts-validation-acfg-0.c
@@ -60,7 +60,7 @@
  * @defgroup TestsuitesValidationAcfg0 spec:/testsuites/validation-acfg-0
  * @brief This validation test suite is used to validate the default value of
  *   application configuration options taking the optional BSP provided
diff --git a/testsuites/validation/ts-validation-acfg-1.c b/testsuites/validation/ts-validation-acfg-1.c
index 2696d789be..92c2e90f83 100644
--- a/testsuites/validation/ts-validation-acfg-1.c
+++ b/testsuites/validation/ts-validation-acfg-1.c
@@ -61,7 +61,7 @@
  * @defgroup TestsuitesValidationAcfg1 spec:/testsuites/validation-acfg-1
  *   application configuration options where all optional BSP provided settings
diff --git a/testsuites/validation/ts-validation-cache.c b/testsuites/validation/ts-validation-cache.c
index 352341ed80..1ea4130597 100644
--- a/testsuites/validation/ts-validation-cache.c
+++ b/testsuites/validation/ts-validation-cache.c
@@ -57,7 +57,7 @@
  * @defgroup TestsuitesValidationCache spec:/testsuites/validation-cache
  * @brief This validation test suite provides enough resources to run tests for
  *   the directives of the @ref RTEMSAPIClassicCache.
diff --git a/testsuites/validation/ts-validation-intr.c b/testsuites/validation/ts-validation-intr.c
index 10bb19a840..4b1074fc4a 100644
--- a/testsuites/validation/ts-validation-intr.c
+++ b/testsuites/validation/ts-validation-intr.c
@@ -57,7 +57,7 @@
  * @defgroup TestsuitesValidationIntr spec:/testsuites/validation-intr
  *   the interrupt controller related directives of the @ref
diff --git a/testsuites/validation/ts-validation-io-kernel.c b/testsuites/validation/ts-validation-io-kernel.c
index 84ba9ef441..6153e8ab18 100644
--- a/testsuites/validation/ts-validation-io-kernel.c
+++ b/testsuites/validation/ts-validation-io-kernel.c
@@ -64,7 +64,7 @@
  * @defgroup TestsuitesValidationIoKernel spec:/testsuites/validation-io-kernel
  * @brief This validation test suite contains test cases which test the kernel
  *   character input/output device provided by the BSP before the system
diff --git a/testsuites/validation/ts-validation-no-clock-0.c b/testsuites/validation/ts-validation-no-clock-0.c
index 820dadcd25..b6e5989727 100644
--- a/testsuites/validation/ts-validation-no-clock-0.c
+++ b/testsuites/validation/ts-validation-no-clock-0.c
@@ -58,7 +58,7 @@
  * @defgroup TestsuitesValidationNoClock0 \
  *   spec:/testsuites/validation-no-clock-0
  *   to run basic tests without a Clock Driver for all specified managers and
diff --git a/testsuites/validation/ts-validation-non-smp.c b/testsuites/validation/ts-validation-non-smp.c
index 9a4a9061ae..9c26d9b286 100644
--- a/testsuites/validation/ts-validation-non-smp.c
+++ b/testsuites/validation/ts-validation-non-smp.c
@@ -57,7 +57,7 @@
  * @defgroup TestsuitesValidationNonSmp spec:/testsuites/validation-non-smp
  * @brief This test suite for non-SMP test cases provides enough resources to
  *   run basic tests for all specified managers and functions.
diff --git a/testsuites/validation/ts-validation-one-cpu-0.c b/testsuites/validation/ts-validation-one-cpu-0.c
index f45e8a4905..8956b66732 100644
--- a/testsuites/validation/ts-validation-one-cpu-0.c
+++ b/testsuites/validation/ts-validation-one-cpu-0.c
@@ -57,7 +57,7 @@
  * @defgroup TestsuitesValidationOneCpu0 spec:/testsuites/validation-one-cpu-0
  *   to run basic tests with exactly one processor and without a Clock Driver.
diff --git a/testsuites/validation/ts-validation-one-cpu-1.c b/testsuites/validation/ts-validation-one-cpu-1.c
index 39852cc510..953f067037 100644
--- a/testsuites/validation/ts-validation-one-cpu-1.c
+++ b/testsuites/validation/ts-validation-one-cpu-1.c
@@ -59,7 +59,7 @@
  * @defgroup TestsuitesValidationOneCpu1 spec:/testsuites/validation-one-cpu-1
diff --git a/testsuites/validation/ts-validation-smp-one-cpu-0.c b/testsuites/validation/ts-validation-smp-one-cpu-0.c
index a52477b507..ddd47bfee2 100644
--- a/testsuites/validation/ts-validation-smp-one-cpu-0.c
+++ b/testsuites/validation/ts-validation-smp-one-cpu-0.c
@@ -58,7 +58,7 @@
  * @defgroup TestsuitesValidationSmpOneCpu0 \
  *   spec:/testsuites/validation-smp-one-cpu-0
  *   to run basic tests for all specified managers and functions in a
diff --git a/testsuites/validation/ts-validation-smp-only-0.c b/testsuites/validation/ts-validation-smp-only-0.c
index 5f65ac7af1..e4eaa3cf0c 100644
--- a/testsuites/validation/ts-validation-smp-only-0.c
+++ b/testsuites/validation/ts-validation-smp-only-0.c
@@ -58,7 +58,7 @@
  * @defgroup TestsuitesValidationSmpOnly0 \
  *   spec:/testsuites/validation-smp-only-0
  * @brief This test suite for SMP-only test cases provides enough resources to
diff --git a/testsuites/validation/ts-validation-smp-only-2.c b/testsuites/validation/ts-validation-smp-only-2.c
index e8897adfaf..0e1b0c1310 100644
--- a/testsuites/validation/ts-validation-smp-only-2.c
+++ b/testsuites/validation/ts-validation-smp-only-2.c
@@ -60,7 +60,7 @@
  * @defgroup TestsuitesValidationSmpOnly2 \
  *   spec:/testsuites/validation-smp-only-2
  * @brief This SMP-only test suite validates the clustered scheduler
  *   configuration through an application configuration with a processor
diff --git a/testsuites/validation/ts-validation-timecounter-0.c b/testsuites/validation/ts-validation-timecounter-0.c
index 3ce34342fb..07e638160a 100644
--- a/testsuites/validation/ts-validation-timecounter-0.c
+++ b/testsuites/validation/ts-validation-timecounter-0.c
@@ -58,7 +58,7 @@
  * @defgroup TestsuitesValidationTimecounter0 \
  *   spec:/testsuites/validation-timecounter-0
  * @brief This validation test suite is intended test cases related to the
  *   installation of timecouters.  The Clock Driver is disabled.
diff --git a/testsuites/validation/ts-validation-timecounter-1.c b/testsuites/validation/ts-validation-timecounter-1.c
index 80440d2e07..aa5873bdb8 100644
--- a/testsuites/validation/ts-validation-timecounter-1.c
+++ b/testsuites/validation/ts-validation-timecounter-1.c
@@ -58,7 +58,7 @@
  * @defgroup TestsuitesValidationTimecounter1 \
  *   spec:/testsuites/validation-timecounter-1
  * @brief This validation test suite is intended test cases related to the use
  *   of timecouters.  The Clock Driver is enabled.
diff --git a/testsuites/validation/ts-validation-timecounter-smp-0.c b/testsuites/validation/ts-validation-timecounter-smp-0.c
index 3c2b3c218c..aef567ab6a 100644
--- a/testsuites/validation/ts-validation-timecounter-smp-0.c
+++ b/testsuites/validation/ts-validation-timecounter-smp-0.c
@@ -58,7 +58,7 @@
  * @defgroup TestsuitesValidationTimecounterSmp0 \
  *   spec:/testsuites/validation-timecounter-smp-0
  *   of timecouters.  The Clock Driver is disabled.
diff --git a/testsuites/validation/ts-validation-tls-0.c b/testsuites/validation/ts-validation-tls-0.c
index 463a460f2e..1016bfccb4 100644
--- a/testsuites/validation/ts-validation-tls-0.c
+++ b/testsuites/validation/ts-validation-tls-0.c
@@ -57,7 +57,7 @@
  * @defgroup TestsuitesValidationTls0 spec:/testsuites/validation-tls-0
  * @brief This validation test suite contains test cases related to the
  *   thread-local storage support.
diff --git a/testsuites/validation/ts-validation-tls-1.c b/testsuites/validation/ts-validation-tls-1.c
index 6a4dbf587b..ea46c4f20e 100644
--- a/testsuites/validation/ts-validation-tls-1.c
+++ b/testsuites/validation/ts-validation-tls-1.c
@@ -57,7 +57,7 @@
  * @defgroup TestsuitesValidationTls1 spec:/testsuites/validation-tls-1
2.35.3
